Old 06-27-2015, 06:01 PM   #11 (permalink)
Thanks Frank. As for rounding the leading edges, I'm trying to figure out how best to do that or what materials to use. Should I cut the sharp edges back and try to find some sort of round edging material, or would it work to cover the edges with something round, say like a 3" plastic pipe cut in half?
Old 06-27-2015, 06:59 PM   #12 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That is a cube. ... what frank lee said... do what the trucks are doing...
Are you reading this thread gojng on right now? http://ecomodder.com/forum/showthrea...ing-32190.html
Lots there applies to you. Good luck!
Old 06-28-2015, 08:53 AM   #13 (permalink)
Joggernot's Avatar
It looks like you're towing a parachute. You should leave the weight on the tongue, along with the aero, and it might tow better.
Old 06-29-2015, 04:23 AM   #14 (permalink)
09 Toyo Yaris HB (Huevos)
My first thought is and Aero wing or wind deflector on the truck like one would find on a tractor trailer rig. Second add a rear aero effect to the back of the trailer with some simple barn door style hinges, 1/4 ply wood, and a few struts. Looks to the current OTR rigs for a little inspiration. As the trailer is short I'm not sure if side skirts would benefit too much.
Old 06-29-2015, 10:46 AM   #15 (permalink)
Joggernot's Avatar
There's a trailer down the road where all but the hitch itself has been used to make the pointed triangle at the front of the trailer. This is a design from the manufacturer. You might have enough room to put the nose on your trailer using the triangle up front.
Old 06-29-2015, 11:23 AM   #16 (permalink)
except vee-noses aren't better aero unless they fill the gap better than a flat nose.
