Old 02-15-2010, 09:19 PM   #1 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
remove exaust resonator for mpg?
my echo has a cat,,,then a resonator,,,,,then a muffler, if i were to replace the resonator with a pipe ,,, i know the noise would go up , but would there be any mpg increase? i dont want to sound like a ricer, but for enough fe i will do it ,,,anybody done this, or have ideas?
Old 02-15-2010, 10:02 PM   #2 (permalink)
My idea is it won't be effective enough for you to tell.
But don't let that stop you. If you have a better means of testing fe than tank-to-tank, put a test pipe in there and try it. Make sure you do an airtight test or we'll rip it apart.
Old 02-15-2010, 10:08 PM   #3 (permalink)
IMO not worth it. Us ecodrivers never use the engine to the extent that needs maximum flow (high engine loads and high rpm).
Old 02-17-2010, 12:25 PM   #4 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
do not remove the resonator
as per the Hotrod exhaust science article
the resonator has a function in the tuning of the exhaust pipe length .
removing it should DECREASE overall efficiency and reduce power output and fuel economy .
as per the article
it makes sense to me.
The Following User Says Thank You to mwebb For This Useful Post:
moonmonkey (02-17-2010)
Old 02-17-2010, 11:03 PM   #5 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
alot of times resonator deals with more than noise, it sets a speed bump for the catatlyst. It is even a set distance from the cat by good engineers. it is often a chamber to allow a quick burp, then slow...to make the cat REALLY function. Every off throttle, and on throttle.
on injecteds with air bypass, the exhaust is not bothered much, with or without,hence the resonator hack on modern turbo cars..it is screaming through the pipes anyway at all times there. For n/a cars, it needs math.
I went into quite an experiment deciphering exhaust for a low pressure carbed car...the highest mpg on planet earth - (for you metrompg)
it still needed a resonator, but nearly hollow, to mimick what fat injected intakes do for the catalyst. The echo could take a more open baffled one and possibly increase mileage, but unlikely. Exhaust Too hot is a good sign to mess with resonator.
Old 02-19-2010, 12:02 PM   #6 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Try it it's only 40 bucks, We did it on our '91 190 E and i didn't really pay attention to FE before and after but it had a little more throttle response, and if it works then you'll have another thing on here that people can do for cheap and it's not Reeeeally loud it just makes your car a little deeper, especially with stock exhaust
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 02-19-2010, 12:04 PM   #7 (permalink)
Just throwing one thing out there, considering your torque usually comes in low 1500-3000 RPM that's the range most of us ecodrivers are in right? I'd say when the engine is producing full torque it probably pushes a bit of air through the exhaust too SO it may be beneficial there
Tank:
Old 02-19-2010, 01:09 PM   #8 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Why are you giving the O.P. advice if you have no idea if it will help or hinder achieving his fuel economy goal?
Old 02-19-2010, 02:06 PM   #9 (permalink)
Si engine and trans
90crxHF's Avatar
CRX Si/HF - '90 Honda CRX HF
90 day: 40.35 mpg (US)
I removed my cat a long time ago, but left all resonator pipes. I had increased throttle response, it seemed to take less throttle, and the noise (out the exhaust pipe) did not increase at all...
I only ever put the cat back on the car for getting it inspected.
~1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race
1/8th: 9.90 @ 71.03, 60' - 2.41 (HMP '08) - 284K on chassis and ~110k on engine
~1996 Mustang GTS/248A - 1/4: 13.447 @ 99.75, 60' - 1.820 (HRP - 959' DA)
http://www.nearlysurrounded.com <-- Check out my band
Old 02-19-2010, 03:06 PM   #10 (permalink)
F150 - '97 Ford F150 Lariat
Taurus - '02 Ford Taurus SE
the 73 - '73 Ford Thunderbird
the race car - '95 Ford Thunderbird LX
The Brick - '98 Buick LeSabre Limited
haha...yeah you do.
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 07:35 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
smaller exaust pipe for mpg moonmonkey EcoModding Central 77 02-19-2010 02:15 PM
Using exaust gas as an aero. aid Cd Aerodynamics 15 04-12-2008 09:33 PM
