Old 07-01-2020, 07:52 AM   #21 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
He probably means pcv
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 07-01-2020, 11:10 AM   #22 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Blaming the EGR for anything and everything is currently a "thing" on Priuschat.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 07-02-2020, 02:20 AM   #23 (permalink)
The only vehicles I've ever seen have pcv problems RELIGIOUSLY are all Chevrolet car profile v8s. Those things need a 1" ID pcv system at minimum to not suck oil. *shakes head*
Old 07-02-2020, 10:47 AM   #24 (permalink)
teoman's Avatar
A3 - '12 Audi A3
The EGR recirculates carbon in to the intake. That can be an abrasive.
3D printers that print carbonfiber filament have rapid wear of the nozzle.
Not saying this is a cause, just relevant things that pop in to my mind.
The Following User Says Thank You to teoman For This Useful Post:
EcoCivic (07-02-2020)
Old 07-02-2020, 12:21 PM   #25 (permalink)
I never thought about that, great point! I blocked off my Civic's EGR because I didn't want my intake manifold getting full of soot and heat soaking from the hot exhaust. I can't really say that I noticed a difference in the way it runs or a difference in gas mileage, but YMMV (no pun intended)
Old 07-03-2020, 03:41 AM   #26 (permalink)
I wish it was more abrasive because I've noticed a lot of people have clogged egr coolers lol
Old 10-03-2020, 03:04 PM   #27 (permalink)
Alright just changed the oil in the Prius. 172k. I put in 5 quarts 9000 miles ago and 2.1 quarts came out. So the car consumed 2.9 quarts. That's similar to 1.6 quarts every 5000 miles. Just changed the oil with a can of 6 cylinder engine restorer and some more 0W-20 oil. So 5 quarts total goes back in and we will see what comes out.
Update:
YUP THE PIG IS SUCKING OIL!
Air filter is clean after 80k miles now. Top side of the throttle body is clean. Back side of the throttle body was oily. Got a screw drive to prop it open... There is literally a reservoir of oil in the intake.
Time to go to Prius Chat and complain.
ID:	29256   Click image for larger version
ID:	29257   Click image for larger version
The Following User Says Thank You to hayden55 For This Useful Post:
Joggernot (10-04-2020)
Old 11-11-2020, 02:26 PM   #28 (permalink)
Update: 3k miles and we have about a 1 quart consumption. Engine Restorer therefore in fact does not help with pcv/blowby related oil consumption on the Prius. (No change in oil consumption)
Next step will be to install the Turbo volvo catch can, and drill a hole in the oil pan for the oil return. I'm feeling pretty hopeful about this one. This should be the solution.
EcoCivic (11-11-2020)
Old 11-11-2020, 11:49 PM   #29 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I scanned through the whole thread, but didn't see it...what kind of oil are you running?
Old 11-12-2020, 09:19 AM   #30 (permalink)
0w-20
