Go Back   EcoModder Forum > AltModding > Saving@Home
Old 04-17-2010, 07:55 PM   #1 (permalink)
Curious....
koihoshi's Avatar
DoesNotHaveANickname - '99 Ford Escort ZX2
Reusing old batteries?
I have some old batteries from my bikes I've saved. Is there a way to bind them together with some sort of tiny voltage they have left and reuse them as small solar batteries? They /are/ sealed batteries, however. Is it still possible to get them back in the game?
Old 04-17-2010, 08:56 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Are these valve regulated sealed lead-acid batteries?
Dead lead-acid batteries are pretty much scrap, as far as I can tell.
Old 04-17-2010, 09:26 PM   #3 (permalink)
Curious....
koihoshi's Avatar
Ah i was afraid of that.
Old 04-17-2010, 09:29 PM   #4 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Battery salvage is a black art, but with practise, quite worthwhile. First, find out what chemistry you are using. Ni-Cad batteries can sometimes be saved by a burst of high voltage to burn out tiny short circuiting elements. So far, we can't even tell if your bikes have pedals or motors.
Old 04-17-2010, 09:33 PM   #5 (permalink)
Curious....
koihoshi's Avatar
My apologies, I should have been more clear. They are from my motorcycles. I'll get some more info off of them when I get home as to what it says on them for the type of battery.
Old 04-19-2010, 09:28 AM   #6 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I'd just recycle them. I don't know about motorcycle batteries, but full size car batteries are worth about $7 each right now at a scrapyard.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 04-20-2010, 12:07 AM   #7 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
when recycling, you don't want this stuff to leak out in your car. that would be bad. dump the battery's liquids out in the front yard.
single person car thread
Old 04-20-2010, 08:05 AM   #8 (permalink)
Left Lane Ecodriver
Now THAT would be colossally stupid. Loovit, why don't you puor battery acid on your keyboard for that one, and think about what you've done?
Remember, kids, when you're transporting wet lead-acid batteries, new or used, orient them NE-SW in your car, and don't take corners too sharply. Only your local automotive recycler is qualified to dispose of lead-contaminated H2SO4.
Old 04-20-2010, 09:17 AM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Why not just dig a hole and drop the whole battery in?
When you recycle lead acid batteries they recycle the lead, the acid, the plastic, pretty much every part of the battery is recycled other then the dirt that's on the outside, that is why when they pay you for them they pay you for the wet weight of the battery, the recycling place wants the full!
Worried about leaking? then don't tip them over, large batteries do just fine under the hood of a car for years at a time, motorcycle batteries are on their side when the bike is on it's side, so unless the battery is busted open you should be fine, it is still a good idea to place the battery on a piece of card board to keep the floor of your trunk clean and if you do have a cracked battery then put baking soda on any spills, you can also dust your hands and cloths with baking soda if you spill on your self or rinse with water, the acid will not eat your skin instantly but if you don't wash it off it can give you mild chemical burns or a dry, chapped skin feeling.
Old 04-20-2010, 04:15 PM   #10 (permalink)
As to getting more use from old batteries, there's not much wrong with making a 36 V pack out of 4 formerly 12V batteries, or some such. Do some testing to see just what you have available. You can even put two of the weakest ones in parallel if they are similar. Keep the weakest link in mind when using the pack. Chemical treatments and/or well-tailored pulses of high-rate charging can revitalize a sick lead-acid battery. Keep track of how much it takes to charge them, VS how much they put out, and baby them individually every few charges. The very latest wonder batteries are 98% efficient. You can compare yours to a healthy battery on your own set-up.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
More smaller batteries vs. Less bigger batteries GooberPea Motorcycles / Scooters 34 02-04-2014 02:56 PM
Battery heating for EV efficiency bennelson Fossil Fuel Free 21 01-22-2010 09:52 PM
Need help with XB-600 scooter - Blew up the batteries! eeraser Motorcycles / Scooters 11 06-16-2009 12:59 AM
GM's Reportedly Road-Testing Lithium-Ion Batteries for the Volt SVOboy Fossil Fuel Free 5 05-25-2008 02:38 PM
