Old 06-18-2010, 12:09 AM   #11 (permalink)
Miles per hour divided by gallons per hour = miles per gallon in my book. Miles per hour is pretty easy, gallons per hour is more difficult especially if you can't get a place to measure it upstream of the injector spill return. A lot of Diesels dump the spill back to the tank to keep the fuel temp low. It sure would be nice to get a real time measurement. I don't know what cruise speed will optimize the mileage on my '81 Rabbit Diesel, but it sure seems like it is about 55 mph, maybe quite a bit higher when drafting.
Air flow is neither here nor there. Not sure why anyone would even try to measure it on a Diesel, unless it was for trend monitoring, like: Is the turbo performance what it used to be?
The Following User Says Thank You to Crazyrabbit For This Useful Post:
Imatech (07-09-2010)
Old 06-18-2010, 07:47 AM   #12 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
They wanted the engine not to smoke under any circumstances, and keep the EGT low. If you don't monitor airflow and you have a gunked up intake from crankcase vent oil and egr soot, you'll get smoke out the back under high load and high EGT.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 06-21-2010, 07:09 PM   #13 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
In terms of a fuel economy gauge its still a moot point though, unless of coarse you are bumping against the limit on your throttle which a good ecomodder doesn't do anyway.
Old 07-09-2010, 07:42 PM   #14 (permalink)
Good records will always show you where you going wrong.
97-99.0 VW Golf / Jetta Diesel, good cars? canhonkey General Efficiency Discussion 5 01-24-2013 10:17 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
1977 VW Beetle diesel conversion on oakland craigslist! JQmile EcoModding Central 58 10-28-2009 02:37 PM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 03:28 AM
(long) Scangauge II vs. old European diesel Renault groar Instrumentation 0 08-13-2008 05:40 PM
