Old 02-04-2012, 02:12 PM   #31 (permalink)
Send a message via AIM to Lethedethius Send a message via Yahoo to Lethedethius
Good stuff, I stick by my comet though, it has roughed the belt up a little bit and just eliminates the squeel.
Old 04-22-2012, 03:34 PM   #32 (permalink)
2004 Toyota Matrix - the lady in the Toyota Service Dept. told me a wire brush works. It takes the glaze off the belt. I thought she implied bushing it while the motor is running? Car Quest told me to NEVER put any kind of stuff on a belt to make it stop squealing. This will make things worse. The 04 Matrix has a Technical Service Bulletin to put a new type of tensioner on, $192, belt $57, (labor $66 (for the belt or the (belt and tensioner))). My belt squealed after 2 years they replaced it. Then every 2-3 years. Car Quest told me to whine at the dealer to get it fixed free but this dealer said no. Car Quest told me that now-a-days there are only 1 or 2 manufacturers of auto parts. He named a company, I forget, and they make the same "Genuine Toyota part" as the cheap no name brand.
Old 04-22-2012, 05:03 PM   #33 (permalink)
They sure know what they want to charge for something as simple and stupid as a belt tensioner don't they.
I did an accessory drive simplification on my Tempo and threw all that junk outta the car. Old school manual tensioning at the alternator FTW!
Old 05-08-2012, 01:33 PM   #34 (permalink)
Glazing is caused by heat of friction from a slipping belt. The pulley gets polished in the process. Belts have had a tendency to stretch after installation allowing them to slip. Under hood temperature has an effect too. I bought an inexpensive belt tension gauge from Gates so I can check the belt tension with the spec. in the Haynes manual. Scuffing the belt and pulley reduces the squeal by increasing the friction. A bad bearing puts a load on the belt that causes it to slip.
Car went belt commando today... prelim. +10%FE gascort Success Stories 18 01-22-2012 12:02 AM
Serpentine Belt Noise mhmitszach Off-Topic Tech 3 06-20-2009 12:38 AM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 02:23 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 05:11 PM
How get a shorter belt........ }{ead$hot Zod EcoModding Central 4 04-24-2008 12:13 AM
