Old 05-17-2010, 10:37 AM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Side window tufts pointing up?
After tuft testing my wipers on a 1991 Civic Wagon, I thought I'd move the tufts to the side windows and compare both sides. I only have a driver's side mirror. No surprise that there's a bunch of turbulence behind the mirror, but I'm wondering what's happening here on the passenger's side.
Why are the front tufts pointing up? Both sides have it, but it's much clearer on the mirrorless side.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Cd (05-17-2010)
Old 05-17-2010, 11:11 AM   #2 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
My VX does the same thing watching water droplets move on my mirror-less passenger side.
Looks like a very small vortex is generated by the trailing edge of the A pillar. But it look s like the flow re-attaches quickly enough.
Old 05-17-2010, 12:05 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
My Insight does the same, with water flowing up the glass on the side where the mirror used to be.
Air is flowing up and over the car in the windshield area. As it wraps around the A-pillar, it still has momentum. I don't see vorticies.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Gasoline Fumes (05-18-2010)
Old 05-17-2010, 12:14 PM   #4 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
i have observed the same thing on my car.
i found a cfd picure that shows what goes on, because of the similar observations i think this happens on most vehicles of this layout.
i suppose this is why the shape of the A pillar is more important than one would guess at first glance.
it seems a somewhat complex effect, and i can't really juge if it's good or bad or where the air should go ideally ( i suppose over the car). but it's interesting to note the airflow seems to originate over the side of the hood, and after it's trip over the sidewindow seems to return to the roof.
perhaps another reason why roof racks might hurt FE!
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following 4 Users Say Thank You to lunarhighway For This Useful Post:
AeroModder (05-17-2010), COcyclist (05-17-2010), Gasoline Fumes (05-18-2010), KamperBob (05-18-2010)
Old 05-17-2010, 01:20 PM   #5 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I noticed that having the driver's side front window open causes that side of my kammback to shake. That CFD model shows why. It's not allowing the air to roll onto the roof and over it.
Having the rear windows open doesn't seem to have any effect. Unfortunately, only the passenger side one works. I'll probably check the wiring on it later and make sure it's connected properly. If not, a new motor might be in order, since I removed the AC and summer is coming.
If you tuft test it again, try it with the window down a crack.
In Reason we Trust
Old 05-17-2010, 03:55 PM   #6 (permalink)
low pressure
The air going around the A-pillars and over the roof is traveling much faster than the ground speed of the car.
To satisfy Daniel Bournouli's ( sp?) Theorem,the pressure must be lower there.
The tufts are attempting to 'reach' the lower pressure regime and achieve equilibrium.
This is why you don't drive with a hatchback open,as the exhaust fumes also want to migrate through the cabin when the front windows are cracked.
Old 05-18-2010, 06:52 AM   #7 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by lunarhighway View Post
I don't recall a vehicle that DIDN'T do that. Good for smokers. Good for releasing other types of cabin fumes as well.
Cheers
KB
Old 05-18-2010, 08:01 AM   #8 (permalink)
I will have to tuft test my zigzag tape on the 'A' pillar -- I think it helps reduce this vortex.
Old 05-18-2010, 10:30 AM   #9 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Thanks everybody! Tuft testing is fun, I might do the whole car!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-18-2010, 10:42 AM   #10 (permalink)
AeroModder's Avatar
Team Ford
I'm not sure if those are large enough to have any effect. Definitely tuft test it.
I found my yarn and masking tape, so I'll be doing a bit of testing myself soon.
In Reason we Trust
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 07:35 PM
Side View Mirror Downsize cfg83 Aerodynamics 20 07-13-2011 12:22 AM
Swede's AeroLid build thread swede Aerodynamics 47 06-09-2010 03:53 PM
2009 Prius Base - $19k Matt Herring Hybrids 283 12-29-2009 03:12 PM
tuft testing on 93 Sentra back window jim-frank Aerodynamics 5 06-16-2008 04:59 PM
