Old 12-22-2014, 10:04 PM   #1 (permalink)
Julia - '11 Toyota Tacoma Regular Cab 4x4
90 day: 26.29 mpg (US)
skinnier tire vs LRR tire?
I'm trying to decide which size snow tires to get. Current tires are 245/75/R16.
Current:
245/75/R16
30.5" diameter
32 lbs
7.6" tread width
Snow tire: Yoko Geolander I/T GO72:
245/75/R16
30.6" diameter (+0.1" from current)
34 lbs (+ 2 lbs from current)
8.2" tread width ( + 0.6" from current)
LRR
225/75/R16
29.3" diameter ( -4% from current)
30 lbs (-2 lbs from current)
7.6" tread width (= to current)
The 245s should be more efficient because they are taller and LRR, but the 225s should be more efficient because they are lighter and skinnier. Which factors are more important?
Old 12-23-2014, 08:06 AM   #2 (permalink)
Tire Geek
CapriRacer's Avatar
As a general rule, size plays a small role in fuel economy. It's more about the tire than the size (as in the difference between specific makes and models of tires has larger differences than the difference in size alone.)
But directionally, a larger tire is better than a smaller tire.
I think that makes the choice obvious.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 12-23-2014, 09:37 AM   #3 (permalink)
Thanks for the response CapriRacer. So, You're saying that the gearing advantage of the larger diameter 245s will offset their greater weight and width?
Old 12-23-2014, 10:25 AM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
The two 245 tires are the same size. Not enough difference to even notice. You need to be at 5% difference to have any effect on mpg.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-23-2014, 10:19 PM   #5 (permalink)
For winter tires forget MPG, I think with a faily light weight Taco the narrower tire will give better on-road traction. I'm pretty sure you won't see a MPG difference that you can point to the tires, but higher ground pressure is better IMO. Apperantly tirerack seems to offer a one size narrower when looking for winters. I remember how well an old escort cut thru the snow with 155x13's.
Old 12-24-2014, 06:52 AM   #6 (permalink)
Tire Geek
CapriRacer's Avatar
Weight is not the best way to determine the difference in rolling resistance. There are too many other variables that have a much greater effect.
And even if you consider weight as part of the inertia to get the vehicle moving, it is a tiny percentage of the whole vehicle - so largely undetectable.
CapriRacer
The Following User Says Thank You to CapriRacer For This Useful Post:
Cd (12-25-2014)
Old 12-25-2014, 05:53 AM   #7 (permalink)
Focus - '05 Ford Focus tdci Futura
In my own experiance width is a factor for rolling resistance. A couple of years back i also had a ford ka. It got 16.5 km/l on 165's. And 14 on 195's. With the same trips
Old 12-25-2014, 06:08 AM   #8 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
that sounds like an awfully large change(15%), same diameter? If not, is it with the new ratio figured? Same tire model?
Old 12-25-2014, 09:58 AM   #9 (permalink)
The 15" 195 were a bit taller. And a different make/type. But i think the diffence is to big for just a different type.
Old 12-25-2014, 02:07 PM   #10 (permalink)
My experience
Personal experience is that tire type can make a lot of difference. The tall skinny tires didn't help mpg at all.
Testing on bike tires has shown that a larger contact patch ( wider tire) yields a lower rolling resistance at the same pressure. I also experience a smoother ride with a wider tire/wheel combo -on both the truck and the bike. It also seems to take less powere on the bike using the wide combo on the bike.
