Old 05-28-2010, 01:21 PM   #11 (permalink)
animated_zombie's Avatar
Alli - '07 Ford F-150 XL
90 day: 13.95 mpg (US)
DIYWRX - '16 Subaru Crosstrek Prem - SE
90 day: 25.3 mpg (US)
Originally Posted by Funny View Post
Just remember that Robert used Fiberglass to give it some durability... I don't know how long you could stand the shame of driving around with pink styro sticking out of your grill...
Well the car is purple, so it would kinda match!
No, what I'm excited about is the fact that fiberglass will work with the insulation.
So, what I've done is make foamboard templates of what I want filled. Seeing has the front bumper needs some body work anyway, when the time comes I'll put my foamboard cutouts in place, and use the epoxy to fill in the gaps. Then bondo smooth, and paint.
Now, this is slightly off topic, but since I'm posting anyway...
If what I'm making is going to be permanent, I have to have a way to get some airflow. I've made a grille induction (similar to the one on the JDM EVO VIII). This leads right into the back of the radiator.
I want the forums opinion on this part before I do it...
While I was looking at the car today, I realized that that the Low-Beam in the driver's side headlight sits right in front of the intake. I don't think that it would be too expensive to pick up a new headlight. So I thought that I could open up that part of the light into a funnel ram-air. This may solve my (potential) over heating issue.
Thoughts? Suggestions?
(I think that this is my 10th post, so if it lets me, I'll post pictures to show what I'm doing).
Old 05-28-2010, 01:37 PM   #12 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Another post that may help with the foam/fiberglass work....
http://ecomodder.com/forum/showthrea...els-10638.html
Jim.
Old 05-28-2010, 02:29 PM   #13 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Bondo is just polyester resin as used for fiberglass with fillers pre-mixed in. It eats styrfoam. For bonding foam to metal, with gaps, use aerosol foam "caulking." Very sticky on a clean surface.
Old 05-29-2010, 12:21 AM   #14 (permalink)
Jim.
Excellent! Very helpful, and inspirational!
Great work!
Hmm.. well I guess that gives me the options of,
using the foamboard as a template
or
learning how to use the aerosol.
Is the aerosol able to be sanding and painted?
Thanks again guys!
Old 05-29-2010, 08:08 AM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Got pics?
Old 05-29-2010, 12:11 PM   #16 (permalink)
Originally Posted by RobertSmalls View Post
Got pics?
I'm not sure if that question is posed to me, or to someone else.
But, if it's to me, then yes.
I'm in a rush out the door (or I would post them here too) but here's a link to my thread with pictures.
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
'97 Chevy Cavalier Install and Questions maverick21016 OpenGauge / MPGuino FE computer 3 05-21-2010 01:33 PM
M.S. Whittingham, inventor of Li-ion tech to speak locally. Questions? Wonderboy Fossil Fuel Free 17 12-22-2009 02:54 PM
Building fresh engine... questions on FE build. Christ EcoModding Central 1 11-24-2008 05:27 PM
Materials for Ecomodding bennelson EcoModding Central 19 05-31-2008 10:13 AM
