Old 05-21-2010, 03:58 PM   #11 (permalink)
darcane's Avatar
There has been some mention of the Stirling engine and here is what I have so you all don't think it's some new savior technology:
The Stirling Cycle is,as is the Erricson Cycle,given a theoretical enthalpy efficiency,as the Carnot Cycle,80%.
In 1955,GM Research Labs were investigating the engine.
In 1973,with the Arab Oil Embargo and 'energy-crisis,' interest was renewed.
GM,Ford,Philips Research Laboratories,Holland,and NASA were all doing R&D with it.
When crude prices fell,so did interest for some.Ford quit it after umpteen millions of dollars spent on it.
GM had achieved BSFCs of 0.418-0.358 pounds/Bhp-hr ( 39% enthalpy efficiency ).
Does that 80% theoretical efficiency account for inefficiencies of combustion or is that just for converting the heat energy into motion?
Much of the inefficiency of a gasoline engine comes from the need to get rid of waste heat (through exhaust and coolant). If you are using combustion of a fuel to power the Stirling engine, you will have to consider that also. I suspect that's why GM's testing was only around 39% efficient.
As project to learn how to use the tools in the machine shop, I built a Stirling engine in college many years ago. I still have it somewhere...
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 05-21-2010, 04:36 PM   #12 (permalink)
80 %
darcane,they're saying that 80 % of the chemical energy contained in the fuel could be delivered to the flywheel as useful mechanical power.
If you had the materials technology to pull it off,which appears to be the sticking point.
efficient engine design user removed EcoModding Central 27 11-24-2014 01:02 AM
Killing a Diesel - a detailed how-to (much info on commonrail technology) Piwoslaw DIY / How-to 23 02-11-2011 03:21 PM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
