Old 01-10-2010, 03:00 PM   #1 (permalink)
Economy Seeker
Struggling with interstate mileage in 2000 Jeep Wrangler with oversized tires.
I've been struggling with a 2000 Jeep Wrangler that I bought used three months ago. I've climbed up to 20.5 mpg from around 17 by inflating tires, cap, rotor, wires, plugs, and switching to full synthetic lubricants in engine, differentials, and transfer case.
What I'm not sure of is why I only get around 18-19 when I take the interstate bypass to work. I drive 55 on it and baby it. When I go through town for my commute, I drive 45-50 and get 20.5, despite stopping and starting through a dozen lights. I've done this repeatedly, devoting entire tanks to each type of commute.
My Jeep has the 2.5L four-cylinder, and came from the previous owner with 31x10.5 load range C tires. Those are 4.5 inches larger in diameter and 2 inches wider in width versus the stock 265/75R15, if my calculations are correct. I'm also guessing that the 6-ply rating makes them a little heavier than regular 4-ply tires.
The Jeep has always had sluggish acceleration, and in 5th gear, it really struggles to accelerate.
So, I added a vacuum gauge. What I notice is that I almost always get better vacuum in fourth gear (12-14 inches) than I do in fifth gear (8 to 10 inches). This holds true for speeds of 45-60. Under mild acceleration, vacuum drops much lower in fifth (can drop as low as 5" or 6") than in fourth (usually stays above 10"). I lose more vacuum going up small hills in fifth and I gain back less vacuum doing down hills in fifth.
I can't be positive, but it feels like it does take more pedal in fifth, but that could just be my paranoia.
I'm wondering if the larger tire diameter is lowering the engine's highway RPMs out of its useful power band? Could that, combined with heavier tires be making my overdrive inefficient, placing too much of a load for that engine speed?
Old 01-10-2010, 03:19 PM   #2 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
Maybe the bad Cd of the Wrangler is costing you that much at highway speeds. It was never designed with high mpg in mind. It's specific purpose is not that of a highway car. Maybe driving the slower commute keeps you closer to the sweet spot, and once you try to go above that range the poor aerodynamics add up to kill your attempts at higher mpg.
The Following User Says Thank You to thatguitarguy For This Useful Post:
Abboq (01-10-2010)
Old 01-10-2010, 06:42 PM   #3 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Smaller tires, just DO IT. So many people don't realize that those things are just stirring air.
The Following User Says Thank You to MadisonMPG For This Useful Post:
Abboq (01-10-2010)
Old 01-10-2010, 11:50 PM   #4 (permalink)
Welcome to EM!
Yes, the oversized tires are bad aerodynamics, and they can't have good rolling resistance, and they are heavy! Tire weight essentially "counts twice" -- it is part of the total vehicle weight that has to be moved; and it has to be spun. The stock tire size with smoother (all-season) tread and say 44psi in them would be better on all three counts.
What is the stock tire size?
Abboq (01-11-2010)
Old 01-11-2010, 12:56 AM   #5 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Do you need a jeep? This is a serious question... just making sure. If you need it, it may be worth considering buying an inexpensive little car with twice the MPG that you use for regular highway commuting and such and just use the jeep for what you actually need it for.
Old 01-11-2010, 12:58 AM   #6 (permalink)
Where's the fun in that?
Old 01-11-2010, 03:08 AM   #7 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
it almost sounds like you have to put numerically higher gears in the jeep to raise the rpms up on the highway to get it in it's efficient range or get smaller tires
Old 01-11-2010, 04:19 AM   #8 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I agree with several ^^^^ about the tires. Those are probably the main problem you are having. If you have the cash get them swapped out.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 01-11-2010, 07:26 AM   #9 (permalink)
You actually want this to be the case. More load means decreased BSFC, and better efficiency.
Old 01-11-2010, 09:44 AM   #10 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
The old EPA sticker that came on your Jeep would have read 18 city/20 hiway with the four cylinder stick. The new revised sticker that would come on it if sold new today would be 16/19. Using this as a ruler shows that you are in the ball park. As for the tires. If your Jeep did come with the 265/75/15s then they would be 30.7 inches in diameter. The 31 in tires will give you a 1% slower speedometer reading and throw off your mpg figures by that same amount. Your 18-19 would really be 18.18-19.19 and your 20.5 would be a decent 20.7 mpg.
I am wondering if you actually have a wrong idea of what the stock size tire was. All of my sources for the 2000 model list the following sizes, diameter, and I have added speedometer/odometer error in case your vehicle should those tires compared to the 31s:
Jeep SE
225/60/16 26.6" 60=69.9 16.5% off
205/75/15 27.1" 60=66.6 14.3% off
225/75/15 28.3" 60=65.7 9.5% off
Sahara
225/70/15 27.4" 60=67.7 12.8% off
225/70/16 28.4" 60=66 9% off
30x9.5x15 30.0" 60=62 3.3% off
Sport
215/75/15 27.7" 60=67.2 12% off
Where did you get the265/75/15 tire size from. That is DARN huge for the four banger!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
mileage, overdrive, tires, vacuum
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
What size lrr tires for my 95 jeep cherokee sport 2wd? I want sMaller than 225 75 15 95CHERJUST EcoModding Central 7 11-14-2011 06:48 PM
Tire size and FE with a Jeep zjrog Off-Topic Tech 22 01-24-2011 10:32 PM
Honda element, vw beetle, jeep wrangler... hans2vt Introductions 9 05-08-2009 04:05 PM
