Old 07-26-2017, 10:44 PM   #41 (permalink)
Amazed..
Alien Vehicles's Avatar
Hey Michael Moore! Thanks so much for the guidance on the flash kit, will check into it. It is definitely the direction we are working towards. Right now we are preparing dual, single and progressive carbs for testing, but have an Ecotrons kit on the shelf waiting for a turn. I have also heard that Ecotrons has it's problems (especially with timing), and am leery. I have read that the 300 EFI will retro to the 250 head...and will probably go there pretty soon. I hear that MS is super complex, but better quality than ET.
Dead on with the hubs, using CR250 hubs with a 20mm axle and deep groove bearings to control the hub and have oversize custom spokes and 3" Excel rims(spokes made by Buchanan's in Ca. especially for them). The Geek does little turning other than highway offramps and such, really designed specifically to run straight, and hopefully...real, real far :-)
Thank you so much for reaching out with a kind word...thank you. Look forward to more sharing!
Have a wonderful week,
Ray
Originally Posted by Michael Moore View Post
I like your project and wish you success with it.
You might look at the Graves Motorsport Flash Tune ECU kit that lets you change the map in the stock 300 Ninja ECU, I'm not sure if they've got one for the EFI-equipped 250s. I think this is what a friend who is building up a 300 Ninja road racer decided to use. About $425 or so and it may be easier to get working than starting with the Ecotrons/MegaSquirt stuff.
Have you considered that your wire wheels will see a lot more side load than they would on a motorcycle? Sidecar outfits have that issue too, the spokes have to be stiffer/stronger to resist the side loads. Perhaps you are using wider than usual hubs to get a broader base at the spoke flange?
I look forward to reading about your continued progress.
cheers,
Michael
Old 07-26-2017, 10:49 PM   #42 (permalink)
Amazed..
Hey Jojogunn, That thing was a whole lot "Hold my beer", but he did it elegantly, and at a weight that still makes me think!! (And through the mountains!!)
Ray
Originally Posted by jojogunn View Post
Another post mentioned the California Commuter. The builder Doug Malewicki has a website:
The California Commuter - World Record Holding 155 MPG Freeway Legal Car!
Old 07-26-2017, 10:50 PM   #43 (permalink)
Amazed..
Wow! i can't wait to see how it progresses! :-)
It's off-topic, but since you like that, here a motorhome that uses the same geometry:
If you find the four-way intersections at the nose top and side you can see the underlying octahedron. Each hexagon requires one narrow pie-cut. If it's metal: butt-weld, then on to the English wheel.
Also, since you mention Bucky Fuller (and crosswind gusts), here's an early version of his Omnidirectional Transport:
The Following 2 Users Say Thank You to Alien Vehicles For This Useful Post:
freebeard (07-27-2017), HHOTDI (07-03-2018)
Old 07-27-2017, 01:30 AM   #44 (permalink)
Ray, if you aren't already familiar with it you should check out this lengthy thread on the Ecotrons system in the Bucket Racing forum at Kiwibiker, you should find some useful information there:
https://www.kiwibiker.co.nz/forums/s...ine-Management
cheers,
Michael
http://www.eurospares.com
Old 07-27-2017, 02:40 PM   #45 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Dose the bow wake from the semis push you sideways or caus a rotation around the center of pressure?
Had a Hyundai Excel that would squirt sideways, (not rotation) just behind the rear bumper of a truck I would get sucked over tord the trucks wake. The trailer/ cab gap only had effect on heavy wind days (30+) As my front bumper would entre the bow wake tbe front got pushed(CP artificially forward) , at my door the force was square (balanced CP) at my rear bumper it would push the back out rotating my trajectory into the trucks path (witbout correction.) (Artificialy biassed ththe rear
Point is;
If its rotating a rudder, fixed or dynamic, balince the CP.
If its squirting sideways , then downforce would be the fix,
Unscientific methodology for testing center of pressure in Dynamic wind.
Place on blocks of ice in cross wind and mesure the side force applied to each wheel center .
clading the spokes
This was popular with bike raicers in the 90's but favor quickly went for profiled spokes over disk,less gain but still a gain in more wind conditions. The disk is better for always in ahead wind ,but roads never seem to cooperate. . If you find your CP off oneway or the other use the disk on the light end this may be what your looking for.
To get more out of the front a-arms without a rebuild/skin . Add a gurney flap.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Old 07-27-2017, 03:25 PM   #46 (permalink)
I have a lottery ticket that's like Schrodinger's cat (I haven't checked it yet). Otherwise any further progress will be in Virtual Reality.
I am following development like OpenVDB (http://www.openvdb.org) and Improbable's Spatial OS (https://improbable.io/).
Eventually (2018), it will be possible to create in-game assets and deploy them across games created in Unity or Unreal engines, viewable across VR head-sets, consoles and smartphones. I intend to flood the world with Gothic geodesic domes. muhahaha.
________
And the carbon fiber spokes I mentioned are the 'profiled spoke' from gumby79.
Old 07-27-2017, 06:20 PM   #47 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 20.05 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 19.2 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.52 mpg (US)
KK Copperhead - '05 Ford Escape XLS
Originally Posted by Alien Vehicles View Post
Hey ECO-AKJ, after getting cheated on Ebay a few times on quality, we now get everything from Superbrightleds.com. They sell all kind of strip lights and other stuff. The headlights a High output from them as well (With heat sinks :-) I think we are about 5 amps draw for all body lights now.
Thanks for the compliment! One of the team engineers, Ned Ryan Doyle, calls it "The Black Bolt"...he is a very cool guy :-)
That is awesome, I will have to check that out, I want to do the tron look on my car...I know, crazy!!!
Staying Focus'd on MPG
Old 07-28-2017, 07:32 AM   #48 (permalink)
Nice project, looks simple but is also well detailed, not an easy thing to pull off.
Seven years and +$200,000...................no wonder I never did this myself.
Years ago my wife had a Geo Metro, I thought I was going to get sucked under the side of a semi-truck tractor trailer when passing or getting passed. It was pretty scary the first few times, but a little mental preparation and a white knuckle death grip on the steering wheel helped.
Thanks everyone for posting, I've read a lot of good observations and advise in this thread.
EDIT: Sort of a Band-Aid but puts down-force right where you want it to go. The mid-wing of a Formula-E...........Porsche just jumped in with both feet so it should get interesting.
Old 07-28-2017, 11:18 AM   #49 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Do truck wakes take a quantum leap between 50 and 70 MPH? I remember that having the Car-Cycle with a cover that closed the front wheel arch "spoilers" on a car top would rock the whole car on high speed freeways, but it never moved when being run on the shoulder with 55 MPH traffic passing and the fin in place. Nor do I have any problem in my Geo Metro, which seldom sees 60, but does run on a lot of ice.
Old 07-30-2017, 11:09 AM   #50 (permalink)
The most stable "at speed" car I've ever been in or have driven is my 1977 Porsche 911 (rear engine).
The laws of physics are completely against this car, yet it is the best at everything.
This proves that if one puts +70 years into mastering a single engineering concept, anything can be done.
EDIT: My wife had two Geo Metro's, they both suffered from what I call "suck under". Perhaps with the majority of large trucks operating with side-skirts this would no longer be the issue it was back in the day.
