Old 04-28-2008, 01:27 AM   #1 (permalink)
Swift brick?
I drive a 1991 Volvo 240 Wagon. Looks more like a brick than a drop of water. Whats are the easiest things to do to increase MPG? Does anyone on here have the same car?
Old 04-28-2008, 01:42 AM   #2 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Easiest, of course, would be to increase tire pressure to the max indicated on the tires. Then grill blocks. Take off roofracks. Those are the really easy ones.
Edit: Oh yeah, take out any junk that will make your car lighter.
Old 04-28-2008, 01:47 AM   #3 (permalink)
Future EV Owner
Has anyone here experimented with putting their wipers in the vertical position when they are off? I know people do that, but I haven't seen any evidience that it works. It seems common sense to me, but I want emperical evidence.
Perhaps Landon can try it out on his cardboard box?
Old 04-28-2008, 08:05 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Some people will take the wipers off the wiper arms to make them stick out less, and then if it looks rainy or starts running unexpectedly, just toss the blades back on.
Welcome to ecomodder!
Old 04-28-2008, 10:23 PM   #5 (permalink)
yea...I'm THAT guy
SL8Brick's Avatar
....Does anyone on here have the same car?
Hi Tom. I drive a `93 245. Mine has already been deracked...I used the IPD plug kit to plug up the holes. I've experimented with a rear lip spoiler and roof mounted vortex generators. And while they clearly change the aero signature and provide a modest increase in stability...neither has yielded any significant FE gain. You can replace your standard metal wiper blades with the new style 'mono-structure' blades.
Also, have you considered removing/disconnecting the OE warm air system to the airbox? The airbox T-stat is a fairly major obstruction inside the airbox and you'll find that the car will breathe a bit better with it removed.
1999 Audi A6 Avant Quattro - 2.8ltr 30v V6/Automatic - 149k miles
1993 Volvo 240 Wagon - 2.3ltr SOHC/Automatic - 323k miles
Old 04-28-2008, 10:41 PM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Yikes ! No no no
It is all too easy to forget and flip them on by habit ...SCRATCHHHHH !!!
Why not just remove the entire wiper arms ?
On my Civic, it is just a single bolt that holds the wiper arm on.
Rain on the way ? No problem - just reach under the seat, grap your wrench and the wiper arms, pull over, pop the hood and pop the wiper arms back on . Tighten the bolts, shut the hood ... and you are off in all of less than three minutes ( maybe less )
Old 04-28-2008, 10:53 PM   #7 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
It just takes 15 minutes to build a wiper windscreen out of sheet metal and pop rivet it to base of your hood. This simple mod gets the wipers out of the airflow.
aerocivic.com
Old 04-28-2008, 11:02 PM   #8 (permalink)
Ha, I don't want to change the look of my car that much.
Old 04-28-2008, 11:15 PM   #9 (permalink)
Future EV Owner
Yeah, that's an option. I'm trying to get around my wife's opinion, however.
Old 04-29-2008, 10:50 PM   #10 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
Uh.. you know that that's like the number one cause that wiper motors fail right? if you turn off your car and the blades aren't back to resting, this puts some stress on the motor, which burns them out a few ten thousand miles before they should!
Its nothing new, it even says in your owners manual, well... most owners manuals anyway.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
The Suzuki Swift is still a super sweet car! SVOboy General Efficiency Discussion 15 11-22-2009 11:17 AM
Final gear drives for GEO METRO, Swift...Firefly Frederick For Sale 7 09-09-2009 12:03 AM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 04:17 PM
ATTN: METRO SWIFT OWNERS (with NO A/C) - Rear Canvas 'Flow Thru' Hatch Cover XFi For Sale 0 03-25-2008 06:59 PM
