Old 07-30-2008, 05:23 PM   #1 (permalink)
Box Dreamer
xB Commuter - '04 Scion xB
90 day: 40.76 mpg (US)
Synthetic Oil save more gas?
If it saves more gas, what is the best brand name? I've heard Royal Purple or Amsoil... If you use synthetic oil, what filter are you using? I doubt regular Fram filter can last 10K without clog.
Old 07-30-2008, 05:26 PM   #2 (permalink)
Crono's Avatar
Pizza Geo - '92 Geo Metro
Last 3: 47.52 mpg (US)
Blazing Glory - '07 Yamaha C3
90 day: 108.96 mpg (US)
The Beast - '86 Pontiac Subird
90 day: 15.6 mpg (US)
Mom's Firefly - '92 Pontiac Firefly
90 day: 35.65 mpg (US)
Noris - '08 Toyota Yaris
90 day: 35.45 mpg (US)
Mirage - '15 Mitsubishi Mirage
90 day: 48.11 mpg (US)
Japan - '08 Suzuki Alto
90 day: 45.88 mpg (US)
I know K&N also makes oil filters. Not sure how much better they are for mileage, but I've heard they do something with the way oil flows back into the engine to give you better starts for bettter engine life. (Which, ultimately would make better gas mileage at a certain point, I suppose? At least it's more efficient in a sense anyway)
Old 07-30-2008, 05:49 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Eh, I'm not too sold on superb effects from synthetic or filters. I can see lighter oil weights, but it would take a lot of lab testing to sell me on synthetics.
Old 07-30-2008, 05:51 PM   #4 (permalink)
6th Gen Coupe - '02 Honda Accord EX 4 cyl
90 day: 28.01 mpg (US)
Zombie Accord - '98 Honda Accord EX
90 day: 24.71 mpg (US)
Ol' Red - '96 Ford F-150 XL
90 day: 14.43 mpg (US)
My car has always burned oil, so I don't bother with expensive synthetic oil anymore. I used to use Valvoline MaxLife Synthetic Blend and I think I got slightly better MPG results but it could be entirely anecdotal.
Old 07-30-2008, 06:54 PM   #5 (permalink)
Box Dreamer
That's why I post this thread again. I did a lot of reading in several forums. People say synthetic oil should save some gas because it lubricates better. However, nobody says he got FE increase like 1 mpg or 2 mpg. If the claim for 2% is correct, cars get 40+mpg must see the increase in FE (0.8mpg) Even it is not exact 2% increase, maybe we can find 0.5mpg increase consistently. Anyone can see the different after using synthetic oil?
Old 07-30-2008, 06:58 PM   #6 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Consumer Reports found no measurable difference in FE or the amont of particulates in the used oil.
Old 07-30-2008, 07:55 PM   #7 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I don't think it makes much difference on FE, but the extended drain intervals are worth it for me.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 07-30-2008, 08:34 PM   #8 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
+ using less oil (better for environment) and might end up costing less in terms of your money plus what your time is worth on changing the oil twice instead of once.
Synthetic doesn't really cost too much more ($5-6) for the oil upgrade plus ($1-3) for the filter upgrade and you only have to get messy once every 7500-10000 miles
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 07-30-2008, 09:03 PM   #9 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
I run synthetic in everything I drive. Synthetics like Mobil1 EP and the like also save wear on your engine. Real synthetics don't push or squeeze out of bearings like conventional oils do. So, say you lean your engine out a little to pick up a few more mpgs and there is a little more detonation than normal. Under certain loads this would equate to a spun rod bearing and no less than having to turn the crank and put new bearings in. Synthetic buys a little bit more cushion for your bearings.
I upgraded some of the internal engine parts in my buick grand national. I yanked the engine and opened it up to find zero carbon buildup anywhere the parts just wiped clean and had near zero wear after 80K miles of spirited turbo driving. Even if I don't see a mpg gain, I'm running it to protect the engine.
Old 07-31-2008, 01:28 AM   #10 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Do you have some sort of references on oil change interval with synthetic? I guess it would depend on filter too?
motor oil, synthetic oil
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Low viscosity and/or synthetic gear oil? Dane-ger EcoModding Central 7 01-13-2008 07:58 AM
