Old 07-30-2008, 11:12 PM   #11 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 geo metro
90 day: 59.91 mpg (US)
HUFFER - '98 Buick Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Buick Riviera Base
90 day: 32.13 mpg (US)
Blue Z - '07 Nissan 350Z coupe
90 day: 34.13 mpg (US)
[QUOTE=RacerX; Has anyone ever made an altenator spin just from air/wind speed?[/QUOTE]
An Automotive altenator that is....
How about a 1 Litre Street rod?
Old 07-31-2008, 07:30 AM   #12 (permalink)
90 day: 51.82 mpg (US)
Assuming it's turning at the same speed as when driven by the engine, it'll use the same amount of fuel regardless of hooking it up to a wheel or a turbine (which won't work - it would require a really big swept area). There's no free lunch.
The wheel-driven idea would cause it to be under-driven at low speeds, so battery voltage may drop and you may save fuel at those times, but the load on the alternator will be higher as the RPM increases and it puts the lost energy back into the battery, so fuel consumption will go up. I can't see any real savings from that approach.
Also worth emphasizing again: discharging a starting battery will dramatically shorten its life. Going alternator-less may be an effective efficiency mod, but it's definitely not a money saving mod unless you have a source of free or cheap batteries.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Drifter (05-10-2022), enator (05-30-2019)
Old 07-31-2008, 07:47 AM   #13 (permalink)
Mad Scientist
Silver Civic - '97 Honda Civic 2 door DX coupe
90 day: 35.57 mpg (US)
Wagon - '01 Ford Foccs ZTX
90 day: 35.46 mpg (US)
MetroMPG,
there is an existing thread here in EM:
http://ecomodder.com/forum/showthrea...roof-4097.html
AndrewJ also did a similar thing, and he saw a similar 10% gain in FE, on page 8:
http://ecomodder.com/forum/showthrea...ics-312-8.html
Larry
Old 07-31-2008, 08:01 AM   #14 (permalink)
Hi Larry - thanks for posting the links. I've participated in both those threads.
It's worth noting that Andrew also found a source of cheap used deep cycle batteries before he started driving with the alternator disconnected.
Old 07-31-2008, 08:30 AM   #15 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
Bad news for me, apparently I have a "serpentine belt" that goes through EVERYTHING including power steering, water pump, air pump, yadda yadda so I can't take that out
I wonder if I can buy a smaller belt and take off just the alternator...
Old 07-31-2008, 08:59 AM   #16 (permalink)
You could buy a shot alternator and tear the guts out to make a sort of idler pulley.
Old 07-31-2008, 09:32 AM   #17 (permalink)
blackjackel: my alternator is not physically/mechanically disconnected, it's just electrically disconnected. The stock belt is still turning the alt pulley.
When I originally wrote this thread in 2006, I had removed the belt entirely and fashioned a replacement to turn the water pump because I wanted to remove ALL alternator losses including bearing and pulley fan. This time, I just disconnected the alternator wire.
Old 07-31-2008, 09:34 AM   #18 (permalink)
Steady as she goes
RacerX's Avatar
Battery's aren't a problem.....Thank's for the info MetroMPG
Old 07-31-2008, 10:19 AM   #19 (permalink)
BBsGarage's Avatar
BBsRide - '06 Toyota Corolla CE
90 day: 31.64 mpg (US)
As far as a switch is concerned take a look at these.
Battery Cut Off Switch - Compare Prices, Reviews and Buy at NexTag - Price - Review
Thanks.
Bill
SippingFuel
Check out BBsGarage
Picture ur Pet
Old 07-31-2008, 11:25 AM   #20 (permalink)
Good stuff, thanks. That gives me some ideas of what to look for. I'm just headed out to see what's at the local auto parts store. I want a non-energized, manual switch / disconnect like some of those, rather than a relay/contactor setup. I won't be switching the thing on/off very often, so I don't need the convenience of a remote dash mounted solution. Opening the hood and flipping a simple switch is fine.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Kawasaki starts promoting its bikes' MPG ratings - best = 70 mpg MetroMPG Motorcycles / Scooters 35 09-09-2010 11:41 PM
Truck Trend claims 10% more MPG with K&N in 2009 Ford F-150 after bogus road test MetroMPG EcoModding Central 102 12-16-2009 06:45 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
