Old 05-18-2008, 10:55 AM   #11 (permalink)
- - '10 Toyota Prius III w/Navi
Hi Metro,
Yep, I have read the Mitsubishi paper, and their goal was to make their wing work better. They had a side benefit of a small amount of drag reduction, side benefit. The EVO is probably somewhat dangerous at speed, without the downforce from the wing, and the VG's.
The aircraft people use them further forward. On most commercial aircraft I have been on one can see the VG's just behind the thickest part of the wing. Yea, they are probably doing that to get them out of the 500 mph boundary layer, but just ahead of seperation at low speeds. The purpose in commercial aircraft is to provide a lower stall speed.
For cars the flow is thrown upward at the wind screen. The boundary layer is tight and laminar just before it goes over the roof on the typical car (not a Prius), but then through momentum jumps well up above the roof. If that upward momentum could be made sideways, the cross section of the boundary layer might be made less. I do not think this is a good use for a car like a Prius, but for cars with the more vertical windshields, yea it might work. This is kinda like those whale flukes, make the fluid flow go crosswise across the flat surfaces to keep it attached.
There is a thread on here which says Tubulence and Vorticity are good if they reduce the cross-section of the total disturbed air, ie the reduce effective vehicle cross section area. Otherwise, your just putting energy into wasteful flow.
Old 05-18-2008, 12:14 PM   #12 (permalink)
90 day: 51.82 mpg (US)
True - and that raises a good point: The 0.006 drag reduction they saw was after they got the wing working better (ie. probably increasing drag). Perhaps the net change without the wing might be more than 0.006.
I still don't doubt the end-of-roof placement of the VG's though. EG: Renault wasn't trying to shepherd airflow toward a wing; they only wanted to reduce drag by minimizing the size of the trailing wake - ie. moving the separation point further down the back glass.
EDIT: and the boundary thickness at the end of the roof is also mentioned in the Mitsu paper: 30 mm.
There's no flow separation at the top of the windshield on modern cars (some Jeeps, SUVs with more vertical glass notwithstanding), so VG's there won't help. Describing the flow as being "thrown upward" doesn't match what a simple photo shows:
Old 05-18-2008, 01:37 PM   #13 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
It's in the right spirit, but it's really not applicable - the stall speed of a commercial aircraft is still too fast for any direct comparison to a car - not to mention, an airfoil is a streamlined body while a car is a bluff body
No, Metro touched on it - but here's a little more info as this isn't the first time I've noticed this assumption. IF we assumed that fluid only entered at the base of the hood, this would be correct - this is not the case, free stream flow enters at all points, including arbitrary distances up the windscreen and AT the boundary layer level of the roof. Flow impeded by the windscreen slightly stagnates - it has less momentum compared to the mass airflow from entering free stream fluid.
Even if the windscreen is near perpendicular, we don't see a huge diversion upwards. Instead, we see stagnation and recirculation - something like this.
That may have been my thread.... If it was, I need to put more emphasis on how we're stabbing in the dark with respect to placement... There's little margin for error... It should also be mentioned, if it hasn't been already - items to perturb the flow (such as VG's) are band aids for poor aerodynamic design.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 05-18-2008, 02:00 PM   #14 (permalink)
Hi Metro and Trebuchet,
You can see what momentum effect of the air in the Jeep picture both after the hood and straight up from the windscreen.
See that one slip streem that goes up, then down, then way up again. That is the effect.
Remember the width of the car applies. So even a 1 inch decrease in flow height will be advantageous. Kinda analagous to lowering the car by one inch.
In the Jeep picture it looks like there is more like 4 inches of cross-section reduction that could be acomplished, but not with VG's.
Looking again at the Mercedes picture. Its there too. Look at the streamline that comes over the hood the closest and follow it. It disappears into the next higher streamline right at the windshield roof transistion, and both streamlines disappear and reappear further back. So, maybe 2 vertical inches of momentum effect, and then a turbulent section 1/3 the way back on the roof. It looks like there is much more tubulence in the boundary layer on the roof from there back, which just degenerates into flow seperation at the C pillar.
Old 07-21-2008, 10:34 PM   #15 (permalink)
Hello,
Is the Corolla a sedan/saloon? How many AirTabs were used? Did any pictures get taken?
Old 07-22-2008, 01:35 PM   #16 (permalink)
Hi Neil - it's a 4 door sedan. Spacing was following the distributor's instructions. No photos, sorry! I intended to get some tuft testing pics, but didn't/haven't yet.
Old 07-22-2008, 01:56 PM   #17 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Using the snow/leaves/debris on my rear window, there's a lot of swirling that happens on the middle surface instead of laminar flow. The Flow Illustrator app seemed to show similar results with detached flow over the lower portion of the window that looks like it reattaches just at the end of the trunk lid.
Maybe I'll pick up a cheap crap camera on clearance and do some testing one day...
Old 08-18-2008, 04:12 PM   #18 (permalink)
Reviving this thread...
I've finally got some photos/video of tuft testing my dad's Corolla with & without the Airtabs.
I'll just say that the difference is pretty dramatic. It's not a case of "well, it looks like there might be a little less turbulence on the rear window" - it's plain as day that the tufts on the glass & trunk lid behave themselves much better with the airtabs on the roof.
SO... why then didn't they appear to make any difference to MPG? Can the energy going into vortex creation be largely cancelling out their aerodynamic benefits apparently seen on the rear glass?
It's worth repeating that I did think there was an audible difference with the VG's on the roof (louder). If I had something I could use to easily measure noise levels, I'd test that too.
Will post the pictures later.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Cd (06-13-2010), Daschicken (03-12-2018)
Old 08-18-2008, 05:25 PM   #19 (permalink)
Good science! Thanks mucho.If we divide the delta Cd by the Cd of the non-VG Lancer,we'll get the percentage drag reduction for the car.Any 2% drag reduction would net the Mitsubishi owner with a 1% savings at 55-mph( 87 km/h ).
Old 08-18-2008, 05:27 PM   #20 (permalink)
Your grade point average just keeps climbing,as we all give you A-plus for the project and report!!!!!!!!! Thanks Darin,really good stuff.
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 70 03-14-2012 12:25 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 01:09 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
