Old 06-27-2012, 08:56 AM   #21 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Way to go, man! I'll be interested to see the FE results.
I'd love to see the looks you're gonna get from people as you drive by!
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
skyking (06-27-2012)
Old 06-27-2012, 03:59 PM   #22 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
OK, I'm back after two distinct legs.
First leg:
Over Chinook pass to the lower valley, sea level to 5430 and back down. Rain in the mountains. Speeds from 60 down to 35.
149 miles, 5.47 gallons, 27.24 MPG
Second leg: Interstate 82 and Interstate 90
Moderate winds
Speeds right at 66 by cruise control. Did some 71 till I got wise.
471 miles, 18.05 gallons, 26.09 MPG. Speed Kills.........economy
truck configuration:
No bellypan. It had been removed for some maintenance and I ran out of time.
No diffiuser. The tail was absolutely open on the bottom.
No grill block on the first leg. DOH! I left it home, and put some cardboard in at the next stop.
Plusses: I did not drop any parts off. The lights worked. The plastic kept the rain off the cardboard.
Minuses: The plastic came loose over large parts of the critical area between 10% and 30%. I think that billowing plastic caused some problems.
The plastic at the cab/shell joint stretched up, also tripping some things.
The sides of the tail are atrocious! I had no time to really address that. Plastic was starting to tear there.
I think I had the incidence too steep to start with, especially considering the less than ideal surface condition. If I had time I could have peeled off the plastic today, no more rain. I was a little concerned it had some structural benefit in some areas, and the leading lip of cardboard looked very vulnerable to peel back without it.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 7 Users Say Thank You to skyking For This Useful Post:
aerohead (06-27-2012), BamZipPow (06-27-2012), Diesel_Dave (06-28-2012), KamperBob (06-28-2012), slowmover (07-01-2012), Sven7 (07-02-2012), t vago (06-27-2012)
Old 06-27-2012, 04:31 PM   #23 (permalink)
26+ mpg at 60+mph--over the mountains with wind and rain, is a truely remarkable accomplishment! My guess is that you would have broken 30 mpg with the belly pan, etc. all attached.
Diesel Dave
Old 06-27-2012, 04:35 PM   #24 (permalink)
Any plans on doing a coast-down test to determine the Cd?
Diesel Dave
Old 06-27-2012, 05:36 PM   #25 (permalink)
Z - '04 chevrolet silverado 1500 Z-71
26 mpg with a full size truck. That is impressive. I can only imagine the looks you get with that cap. I put a aero cap and huge spoiler on the front of my silverado, and it draws looks no matter where I go, and mine is nowhere near the size of yours. Gives me inspiration to continue on. Thanks
Old 06-27-2012, 07:09 PM   #26 (permalink)
skyking's Avatar
Any intentions of doing a more permanent version?
I will probably use the truss sections up to the back of the bumper, cut them there, and use as a foundation for an aeroshell. I may use the tails that I cut off to make a plug-in boat tail. Or not
2003 TDI Beetle
2002 TDI Beetle
Old 06-27-2012, 07:45 PM   #27 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Shoot, you basically got about double the EPA combined estimate for that truck - excellent!
I've done a few wood aero mods myself... Nothing as elaborate as what you took on though!
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
skyking (06-28-2012)
Old 06-27-2012, 09:02 PM   #28 (permalink)
skyking's Avatar
Maybe when I put it back on. I have it 90% removed now. Installed yesterday morning, removed today. Whew!
I am hoisting it up in the carport for now. If I have any decent length driving trips to do, and I don't need to move the 5th wheel, I will re-install it and do some tweaks.
I think lifting it up a few degrees will not hurt a bit.
2003 TDI Beetle
2002 TDI Beetle
Old 06-27-2012, 09:51 PM   #29 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Looking good, Man. Did you notice many camera/phones pointed in your general direction?
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
The Following User Says Thank You to JethroBodine For This Useful Post:
Old 06-27-2012, 11:59 PM   #30 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
Nice clean lines.! I have started an aero nose for my 99 2500 slt , If I can get my son to add a picture Ill do so. just ribs at the moment. started on sunday 6-24-12 I am making paper templates of all parts for duplicates if it does what i think it would fit your rig I think
The Following User Says Thank You to ron For This Useful Post:
