Old 01-16-2015, 05:24 PM   #31 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
It's only a $250 camera. It's been very useful for my house so far. I found part of my ceiling that was missing insulation. I NEVER would have seen that without the camera. (Yes, I've insulated it since then. I was fortunate that it was accessible.)
Using the Flir One as a night vision device works, but only OK. The thermal imager is pretty low-res. Normally it creates a combined image from the visible spectrum and thermal range. The image from the visible spectrum gives the final picture its detail and edges.
In the dark, with thermal only, the image is blurrier and harder to tell what is what. Other than that, the thermal portion still works well and can see temperature differences at a distance pretty well.
I'll have to see if I can take a photo of the neighbor's dog at night some time.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 2 Users Say Thank You to bennelson For This Useful Post:
oldtamiyaphile (01-16-2015), pletby (01-17-2015)
Old 01-17-2015, 01:57 AM   #32 (permalink)
Sounds like a smart phone version of the fluke thermal imager.
Old 02-26-2015, 01:29 PM   #33 (permalink)
I have the seek thermal version. I find the resolution much better when switched to monochrome. I havent used it on my car yet.....
Old 02-26-2015, 02:14 PM   #34 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Cool thread! Thank you EM monthly email...
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 02-26-2015, 02:16 PM   #35 (permalink)
Bimmer - '02 BMW 325ci
90 day: 23.79 mpg (US)
Yea, these are very cool. I've been planning to get the new FLIR one when it comes out.
Old 02-27-2015, 06:01 AM   #36 (permalink)
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
i looked for thermal images of the prius hw20 some month ago. thank you!
because our prius is driven sometimes from door to door, it would be good to keep amap heat inside. so i go for mirror foil the edges of the hood and maybe set some foam on top.
i´d like to see some more pics. after a drive in diffrent states of cooling out. maybe under the hood?
kurzer Gruß
Prius II
Hyundai Santamo
Old 03-02-2015, 02:19 PM   #37 (permalink)
It's possible to rent these cameras at some home improvement big box stores. Since they are rather spendy, and you'd really only want them for a day or two, that might be the way to go.
The tires are always going to be warm, that's where all the energy from the rolling resistance is going. Even at a real high psi, the lugs are going to wiggle around and get warm, especially with the soft compounded siped snow tires like OP has.
Old 03-04-2015, 04:49 PM   #38 (permalink)
Phantom Blot (Spökplumpen in swedish) - '75 Saab 96 V4
90 day: 52.77 mpg (US)
A thermal camera could be an easy and quick way to test out the (relative) rolling restistance on a bunch of different tires or compare different pressures. -Just put one of each type as front wheels, drive fast for ten minutes and compare temperature with the camera. It may not be exact science, but will probably give a much faster and more reliable result than changing all four tires, check downcoast distance and hope the weather don't change before all 4*n sets of tires are tested...
Old 03-04-2015, 04:59 PM   #39 (permalink)
A regular (and cheap) IR camera could be used for that too.
camera, flir, heat, thermal
