Old 07-16-2021, 09:56 PM   #71 (permalink)
thingiverse.com/thing:Mustang S550 Side Skirt Air Deflector
by silvlerbullet0071 August 07, 2020
The pictures won't hot-link, but it's a 90% (needs beveled edges) of one particular Mustang part.
If you [were to] send me a dimensioned drawing I could return an .STL file.
Old 07-19-2021, 07:07 AM   #72 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by California98Civic View Post
Which is the "D" shape that you identify as best? It seemed like the "D" shape was among the best but that it was equal to the "I" shape at 1.17 and the "O" shape. I must have misunderstood.
This is the D shape on the rigth and second best triangle shape on left. Difference between these two in my tests 0,6-1,0%.
But like I wrote even that can be improved with many tricks and fine tuning. Those can be seen in this video:
https://youtu.be/EDYYMPKPSKs
In final setup I did not have time to build D shape to the deflectors and they are the triangle shapes in final configuration. Building the Triangles took about 1 hour and the D shape ones would have taken almost triple the time. Plus I did not want to break the best deflectors the D ones which work with the wider tires so they are saved for future testing
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 07-19-2021, 11:07 AM   #73 (permalink)
Long time lurker
AeroMcAeroFace's Avatar
Maybe an elongated D shape would be better, an elipse cut in half. A bit like the daihatsu UFE-II
Old 07-21-2021, 03:15 AM   #74 (permalink)
Vekke -- Similar to the deflectors I posted about at #71 Here are some wheel inserts for the Leaf and Hyundai Ioniq:
Hyundai Ioniq Electric 28kWh wheel trim inserts
by xiziz July 20, 2021
https://www.thingiverse.com/thing:4913259
Nissan Leaf alloy rim aero inserts ("Leaf Petals")
Published 3 years ago by Paul Kennett
https://www.myminifactory.com/object...-inserts-76399
IRONICK (07-21-2021)
Old 07-21-2021, 08:15 AM   #75 (permalink)
IRONICK's Avatar
The idea is brilliant, but still need some small holes for the brakes ventilation.
Old 07-21-2021, 01:48 PM   #76 (permalink)
The Nissan Leaf example does have slots around the hub.
Old 07-21-2021, 02:04 PM   #77 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Hyundai IONIQ PHEV, a bit of both spat and deflector:
The Following User Says Thank You to jakobnev For This Useful Post:
California98Civic (07-21-2021)
Old 07-21-2021, 02:37 PM   #78 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I like how the photo from jakobnev shows the curve on that spat following the entire contour of the wheel well opening at the bottom. That's interesting. The spats used to be short little things. That rounded section in front must be doing some interesting stuff with the flow to the inside of that tire.
aerohead (07-23-2021)
Old 07-21-2021, 04:10 PM   #79 (permalink)
I think it's a wickerbill that flips air up into the inner wheel well for whatever reason.
California98Civic (07-22-2021)
Old 07-22-2021, 02:10 PM   #80 (permalink)
Cyborg ECU
Yeah, that makes sense... for pressure? For brake cooling? For both?
