Old 07-27-2015, 08:15 AM   #21 (permalink)
GreenHornet's Avatar
Originally Posted by phyregod View Post
I'm doing way too much research. I've found the smart Fortwo's front tires are Continental contiecontact EP 145/65-15. 12 pounds tires. LRR design. The only wheels on the planet I've found that will fit them and the Crx are Toyota Yaris 15x5 steelies at 16 pounds.
That is +~6 pounds per corner vs. the insight combo. And another 2.5? Pounds per corner for spun aluminum moon discs. Total guess at the weight of the disks.
They are also only 1.5% taller. 900 revs/mile vs the stock 913.
But the kicker is, they're 20mm skinnier per corner. That is 80mm less contact patch width total vs. both stock and the insight.
Stop and go would suffer, but I would, in theory, gain mpg at cruising speed. But if +1.5% isn't big enough to keep me in lean burn, it's all for naught.
I have the Honda Insight gen1 15" donuts and they are 4" wide and lighter than the Yaris steel wheels. I was going to use the Continental Tires with a modified version of these Insight wheels for a car project of mine. You can purchase them from Ebay for around $50 USD.
GH
The Following User Says Thank You to GreenHornet For This Useful Post:
phyregod (07-27-2015)
Old 07-27-2015, 08:50 AM   #22 (permalink)
!!ytinasnI
PhY-49 - '90 Honda CRX Si
Will they hold a standard hubcap? (Moon disc)
Old 07-27-2015, 09:44 AM   #23 (permalink)
That I am not sure bout I have never tried but I am sure that one of us ecomodders can get something rigged up to work :-) This is what we specialize in after all You did notice I said modified version of these Insight Wheels in my previous post
Old 07-27-2015, 10:27 AM   #24 (permalink)
!!ytinasnI
What did you do to them? Also, they're all $100ish shipped on eBay. : (
Old 07-27-2015, 02:45 PM   #25 (permalink)
Crap all this talk about Honda Insight wheels and RE92 tires got me messed up LOL sorry for the confusion I probably caused
The wheel is actually a Honda Fit not Insight wheel from an 09 10 or 11 year Fit car. Bolt pattern is the same and I think cost is why I went this route instead of the Insight cuz you are right the Insight wheels are more spendy. You can definitely get the Fit wheels shipped for around $50.
Here is a link to one currently on Ebay = 09 10 11 Honda Fit Wheel 15x4 Spare 742470 | eBay
Old 07-27-2015, 02:48 PM   #26 (permalink)
It looks like there are some Civic wheels on there also in 15 X 4 that are even less shipped for like $35. I think they have a 5 lug bolt pattern however. Lots of options for those Conti tires though.
Old 07-27-2015, 03:58 PM   #27 (permalink)
!!ytinasnI
Do you have a pic of them on your car? Are you using spacers? Concerned about offset..
Old 07-30-2015, 11:48 PM   #28 (permalink)
I do not have these wheels and tires currently on a vehicle. If you are concerned about the offset just check what the Fit is and that should tell you if they will work on your CRX without modifications such as spacers. I believe the CRX has a 4 lug 4 X 100 bolt pattern which is the same as the Fit. So lug pattern should not be an issue.
