Old 06-12-2009, 10:27 PM   #21 (permalink)
Originally Posted by skyl4rk View Post
Thats new to me. Why does the air flow in an angle, if the car is going straight? Pressure from the front end of the car moving to the outside?
Bow wave off the nose flows laterally around the front of the car, and if unfaired, the front wheels act as a flow fence impeding the bow wave, creating drag.
The oblique angle is greater than I would have thought, until studying a photo in the Hucho book, showing a smoke stream around the front of a Calibra (I think). In that pic, the smoke stream angled about 60 degrees outboard from centerline. Maybe somebody with Hucho who can post pics can find and post it here for us.
For your car, tuft testing would be cheap and easy. Perhaps the tufts could be mounted on inverted Ts 2-4" under the nose, so visualize flow several inches below the body, as the air moves rear toward and around the front wheels. Then, set the incidence of the deflectors accordingly.
Old 06-13-2009, 10:48 AM   #22 (permalink)
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
I came across a newer BMW 325i in a parking lot, thought of this thread and snapped a couple pictures.
They look to be designed like this.
http://i42.tinypic.com/2lih6jr.jpg
http://i40.tinypic.com/8ydpus.jpg
Maybe they also block air from the front suspension?
Old 06-13-2009, 02:37 PM   #23 (permalink)
Extreme Deflectors
The GM Sunraycer scored Cd 0.088 in the windtunnel and Cd 0.12 in full-scale race trim.The car originally had fairings fore and aft of the tire/wheels.That car was prone to lift,and when the nose took off,the area of the wheel fairings acted to turn the car sideways,which would dis-qualify it for competition when exposed to gusts from triple-trailer trucks in Australia.------------ Later,HONDA,with their Dream-2 Solar car,included the wheel fairings and the Drag coefficient fell to Cd 0.10.So the fairings can make a measurable difference.If your going to spend time messing around with this sort of thing I would encourage you to look at the Dream-2 and use it as your model,or Ford's Probe-IV concept car.-------- The flat panel as you see employed on contemporary cars has a drag coefficient of Cd 1.11 in free-air,and unless carefully sized in a windtunnel,as others have mentioned,you could easily oversize them,shooting yourself in the foot in the process.
Old 06-13-2009, 06:24 PM   #24 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
alohaspirit -
Thanks for this thread. I think my "reverse mudflap" configuration has been in error all this time. Based on all this info I think I need to adjust my "straight down" horizontal mudflaps to look more like the OEM ones on production cars :
What you don't see in this front view is that they are straight down. I think I also need to either angle them a bit and/or create a sloped frontal edge to help the air transition better.
CarloSW2
American Solar Energy Society
Old 12-17-2011, 11:07 AM   #25 (permalink)
Enthusiastic EcoModder
Gnatmobile - '96 Geo Metro LSI
90 day: 44.68 mpg (US)
theRAV - '01 Toyota RAV4 NV
90 day: 21.07 mpg (US)
ACCELICA - '95 Toyota Celica GT Convertible
Last 3: 23.46 mpg (US)
The Van - '05 Chevrolet Uplander LS LWB
90 day: 21.04 mpg (US)
Behind the tire, make a long trailing edge that comes to a point. In front of the tire, either do nothing, or put a small rounded deflector that approximates the curve of a naca foil.
Between the front and rear tires, you can put in a catamaran which is a box between the wheels.
What you've described here is basically what Aerocivic has done here: he has deflectors in front of the tires, long parallel channels (like double sideskirts) running the distance between front and back tires along the outer and inner edge of the tires, and a mini boat tail shape after the rear tire.
This whole thread has been really informative for me as I consider what's best for my metro which already has a full bellypan.
I'm willing to build catamarans but I think doing the airfoil shape before and after front AND rear wheels like suggested in Post 11 (I imagine I should only angle the foil for the front wheels as air is traveling more head on by the rear wheels?) would might prove effective and would allow for better clearance of driveways and the like.
What do you guys think?
"You too can get 50 Miles per Gallon, all it will cost is your self-respect."
Old 03-21-2012, 08:56 PM   #26 (permalink)
The Truck - '02 Nissan GU Patrol ST
Just been doing some research on this, and found this thread which answered one of my questions, as to why the air deflectors on my Subaru Forester are pointing inwards.
Now the other thing I was looking at with it is, it has a front pan, which is ok, but not perfect, I have done an upper grille block and I want to put a 3-4" dam on the front as well, to guide more air away & into lower grille & to sides rather than under, then put another pan on which would run from the bottom of airdam and to the base of current air deflectors, which are also inline with where the current pan finishes. So the new pan would finish at the same level as current pan, but would only have about 1-2"s of slope from front bumper, whereas the current pan has about 5-6"s of slope, the new pan would also be completely flat across the width, whereas the current pan is lower in the middle and then goes up at sides and is a bit messy where it joins up with bumper infront of wheels.
I think this would be better aero, any comments?
Would it be worth making the pan a little lower just at the edges infront of the wheels, maybe just an inch or so, to direct more air lower infront of the tyres?
Old 03-22-2012, 04:47 AM   #27 (permalink)
Had another thought also to add a half inch lip to the pan under the airdam to act as a splitter, giving a clear seperation of air going up & around to the air destined to go under.
Old 03-22-2012, 09:02 PM   #28 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
I thought I would help out by posting picture of the 2012 Prius (standard) wheel flaps.
ID:	10543   Click image for larger version
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
The Following User Says Thank You to F8L For This Useful Post:
kurzer (03-26-2012)
Old 03-23-2012, 06:09 AM   #29 (permalink)
What's the hole about between the flap and upper body, is that to let air through to the brakes?
Looking at that limited image, looks very similar to the Subaru design as well, Does that mean the Subaru then probably has good aero there if it is pretty much the same as the Prius?
The more I think I understand, the more confused I get.
Old 03-23-2012, 09:27 AM   #30 (permalink)
F8L
F8L's Avatar
Got me. I found it odd as well. The Prius rarely uses the hydraulic brakes. Regenerative braking slows the car down the majority of time so heat shouldn't be an issue unless the regen components get hot?
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Bounce Test for Rolling Resistance? Ernie Rogers General Efficiency Discussion 14 05-25-2009 06:38 PM
