Old 06-13-2021, 02:22 PM   #21 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.54 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 29.37 mpg (US)
Rear Speakers
Original rear speaker:
Completely removed and replaced with polyethylene cover and butyl tape:
Original speaker weight is 229 g. (including wiring up to the door connector and fastenings):
Be honest, I expected much more... but we have what we have.
Replacement weight is 20 g. only (polyethylene + butyl):
Note #1: I did only one side (left) for now, will replace righ side next time.
Note #2: Also, removed some insulation, but don't count it for now. I will weight all the removed insulation some time later.
Total weight reduction with this fix: 0.209 kg.
ID:	30855   Click image for larger version
ID:	30856   Click image for larger version
ID:	30857   Click image for larger version
Old 06-13-2021, 03:52 PM   #22 (permalink)
Originally Posted by alexshock View Post
Switch 205/55R16 Bridgestone to 195/65R15 Dunlop
It's worth to consider not only the weight savings, but also how a narrower tyre may decrease rolling resistence.
alexshock (06-13-2021)
Old 06-13-2021, 04:30 PM   #23 (permalink)
alexshock's Avatar
They are rated as "B" in RR.
According to EU standards, this rating is absolute for any tyre size, not relative. So this set is pretty good from RR perspective.
Old 06-29-2021, 06:58 AM   #24 (permalink)
alexshock's Avatar
Highway
Had a lot of highway driving last weekends (110-130 km/h) and FE drops significantly.
5.51 L/100 km (42.69 mpg) - does not look good.
It is time to think about some aeromodding...
Old 06-29-2021, 08:00 PM   #25 (permalink)
Sure the rating is absolute for any tyre size, yet we can expect a smaller and lighter set to perform better regarding this perspective. A lower unsprung mass usually is pointed out as a performance advantage anyway.
Old 07-03-2021, 11:45 AM   #26 (permalink)
alexshock's Avatar
Reae Speakers: Reight Side
Just found some time to remove the second rear speaker:
So, total weight of both rear speakers and rear speaker's wiring: 420 g.
Yet to do: remove front part of the wiring from the door to the headunit.
ID:	30960   Click image for larger version
ID:	30961   Click image for larger version
Old 08-18-2021, 04:35 PM   #27 (permalink)
alexshock's Avatar
On-Board Diagnostics
Purchased a good OBD2 adapter and installed some useful apps to check hybrid system data.
My main area of interest is temperature (ICE, electric motors, inverter, etc.).
ID:	31150   Click image for larger version
Old 09-21-2021, 12:43 PM   #28 (permalink)
alexshock's Avatar
I'm thinking on installing flat underbody....
Today I have measured half of the car and bought a sheet of PP to prepare mock-up.
Preparing a PVC model, ready for fitment check:
Old 09-21-2021, 07:34 PM   #29 (permalink)
Are you considering to keep PVC at some areas less prone to get it damaged by heat or would you rather make the undertray entirely of a more resistent material?
Old 09-22-2021, 02:43 AM   #30 (permalink)
alexshock's Avatar
Definitely more resistent. My goal is to make a combination of alumnium + fiberglass.
PVC - is only a model to define final form, dimensions, holes, etc.
After several experiments with different materials (PP, carton, other plastics, etc.) during this summer, I found that PVC (foamed PVC) is the most suitable for making a model.
The Following User Says Thank You to alexshock For This Useful Post:
fusion210 (12-26-2021)
