Old 12-03-2010, 10:36 PM   #1 (permalink)
Transporter - '07 Diamondback Transporter
Echo - '00 Toyota Echo
90 day: 32.98 mpg (US)
Toyota Echo
I recently got a 2000 Toyota Echo and I was wondering how it scores in terms of eco-modder capacity. It gets pretty good mileage so far (33 city 42 hwy) but what else can I really do with this car?
Old 12-04-2010, 08:13 AM   #2 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
It is an excellent, highly efficient vehicle, good choice. If you have a manual transmission, learn to engine off coast and you will see amazing increases in fuel efficiency.
Nissan Versa Aeromods
Old 12-04-2010, 08:22 AM   #3 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
With numbers like that I'm assuming you've got the manny tranny, but give us the deets. What are you willing to do? Bear in mind that 33 city is pretty darned good, even compared to current offerings.
Quick and easy stuff: weight loss, smoothie wheel covers, antenna removal - all small, incremental measures that add up.
Old 12-04-2010, 10:02 AM   #4 (permalink)
By looking over the 100+ ecodriving tips you can pretty easily push that car to 50+ mpg in the summer if its manual. At the very least high 40s. If its auto your numbers will be lower. If you go at it with P&G and engine off coasting I'm sure you can come close to 60 mpg. Your car isn't all that different from my Paseo.
Old 12-04-2010, 08:25 PM   #5 (permalink)
I've only had it about a month and the first two tanks I was getting around 32 mpg but this last tank which was mostly city driving I got up to 33. The first thing I want to do is get a scangauge. It really bothers me not knowing the engine rpms and it'd be great to see current gas consumption. I've thought of deleting the antenna once I get a cd play in it. Is engine off coasting bad for auto trans?
Old 12-05-2010, 09:54 AM   #6 (permalink)
skyl4rk's Avatar
Probably, I would not EOC with an automatic. You can get good results coasting with the engine on, learning to take your foot off of the gas at the earliest opportunity.
A Scangauge is great for learning fuel efficient driving techniques.
Old 07-11-2011, 10:41 PM   #7 (permalink)
nice try but no cigars for me.... i was attempting 1000 kms on a tank of gas, finished at 935 kms....that is 581 miles....on 43.5 litres or 9.56 imperial gallons or 11.5 U.S.gallons.works out 60.7mpg imp. or 50.4mpg US......on an echo 2004 man. with 300,000 kms or 186,000 miles on it. Can someone verify my numbers? thanks.
Alain
Old 07-11-2011, 11:52 PM   #8 (permalink)
Those numbers look great. Congrats on the great mileage, and welcome to the site!
The Following User Says Thank You to Daox For This Useful Post:
alainmci (07-12-2011)
Old 07-12-2011, 12:05 AM   #9 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Those numbers are dead on. I still believe the 1000 km mark is possible with the Echo. It is my aim.
The Following User Says Thank You to CigaR007 For This Useful Post:
Old 07-12-2011, 01:23 AM   #10 (permalink)
perhaps an engine off switch is the way to gain 65 more kms.....
Has anyone converted/modified a 2003 toyota echo? trdfreak03 Hybrids 7 06-11-2012 02:09 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
ScanGauge II speaker mount for 2001 Toyota Echo alohaspirit DIY / How-to 7 02-06-2010 05:29 AM
Engine off switch in a Toyota Echo johnnymac EcoModding Central 1 12-24-2009 03:41 PM
Toyota Echo power steering delete mod? zman EcoModding Central 29 05-17-2009 08:36 PM
