Old 03-10-2025, 09:13 PM   #11 (permalink)
What is the load/unload cycle? Do you back up to a dock or use a ramp and hand truck?
Suppose you could swing the door open only about 90-12 or 78 degrees. That would accommodate a fixed boxed cavity rather than a trailer tail.
The flush, potentially curved, surface would improve over the step and gap of a hinged solution. Not yet sure what would happen across the top.
HI,
Just curious but isn't the trailer tail basically a boxed cavity ?
Also, In some of the trailer tail pics I noticed that the sides and / or the bottom panels don't go down as far as it could (or should ?) does this hurt efficiency?
When I build the trailer tail my idea would be to go down more or less to where my rear bumper is (or would have been if I in fact had a rear bumper (the van did not come with one and I hacve not been able to find one at a junkyard).... I'm guessing that would be best for drag reduction?
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
Old 03-11-2025, 01:15 AM   #12 (permalink)
A boxed cavity should be airtight. More like a truncated boat tail.
They're incomplete because the trucks must back up to loading docks.
Xist (03-12-2025)
Old 03-11-2025, 08:13 PM   #13 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Please delete room for
Old 03-12-2025, 06:58 PM   #14 (permalink)
Your post is definitely shorter than many I have made, but I need to get back to staying in grad school, so I asked Gemini to summarize #1:
The Goal:
Improve fuel efficiency (currently 26 MPG at 62 MPH) on a 450-mile daily bread delivery route, saving on $58 daily fuel costs.
The driver wants to implement a folding "trailer tail" on their Sprinter van.
Challenges:
Frequent cargo access (9 stops) prevents a fixed boat tail.
Difficulty visualizing and designing the folding mechanism for the trailer tail.
Limited metalworking resources, leading to a plan to use marine-grade plywood.
Adapting a trailer tail design to a van's tapered rear profile.
Addressing potential gaps between the van's body and the trailer tail.
Figuring out the proper angle for the tail (12-15 degrees?).
Needing to keep the doors able to open, and lock into the open position.
Proposed Solution:
Construct a folding trailer tail from 3/8-inch marine-grade plywood.
Use existing hinge holes on the van's doors, possibly reinforced with metal stock and piano hinges.
Utilize all-thread and clevis ends for movable connections.
Address door opening limitations with cargo trailer hardware or modified magnetic door holders.
Consider vortex generators before the tail.
Key Questions:
How to design and build the folding and locking mechanism?
Is marine-grade plywood suitable?
How to adapt the design to the van's tapered rear profile?
How to minimize the impact of gaps between the van and the tail?
Is 12-15 degrees the optimal angle?
Are vortex generators beneficial?
#6
Key Points:
Door Folding Necessity:
The user folds the van's rear doors flat against the sides for space efficiency at delivery stops, especially in tight parking situations.
Simply opening the doors 90 degrees or having a fixed boat tail would obstruct roadways and sidewalks.
Parallel Parking Challenges:
A fixed boat tail would significantly hinder parallel parking due to increased vehicle length.
This reinforces the need for a foldable design.
Van Size:
The user primarily uses a longer Sprinter van for increased cargo capacity, making deliveries more efficient.
Alternative Aerodynamic System:
The user discovered a "utility aerodynamic tail 2" system, which involves a small ramp-like structure at the rear of the vehicle.
The user is unsure how this ramp reduces drag, but the company claims it improves aerodynamics.
The user is considering this as a potentially simpler alternative to a full trailer tail.
The user is skeptical of the ramp system, due to lack of use, and the proven benifits of a trailer tail.
Picture Reference:
The user mentions providing a picture of the "utility aerodynamic tail 2" system.
and #7
Alternative Vehicle Considerations:
Volkswagen Jetta Station Wagon with Trailer:
The user considered using their Jetta, which achieves up to 53 MPG unloaded, to tow a 6x12 enclosed trailer.
They acknowledge uncertainties about the trailer's weight and the impact on fuel efficiency when towing.
They need to calculate the weight of the bread cargo.
The Jetta currently needs a head gasket repair and a trailer hitch installation.
There are also concerns about the Jetta's towing capacity in the USA, as opposed to European models.
Minivan:
The user's minivan, which achieves 24 MPG unloaded, is deemed unsuitable as towing would further decrease fuel efficiency, making it less efficient than the Sprinter van.
Other Vehicles:
The user struggles to identify other vehicles that would offer competitive fuel efficiency.
Sprinter Van Advantage:
The user already owns the Sprinter van, which simplifies the situation.
Key Points:
The user is actively trying to find the most fuel-efficient solution.
The Jetta with a trailer is the most promising alternative, but it involves significant modifications and uncertainties.
The user is aware of the convenience of using the Sprinter van that they already own.
The user is trying to find a balance between fuel efficiency and practicality
Would heavy-duty drawer slides work for extending the tail? Hopefully, sheet rubber could help seal the gap.
Members on here used to experiment with conveyor belts.
The point about the gaps on the corners of trailer tails is interesting.
It shouldn't have been too difficult to create fold-down flaps to seal the gaps.
What about a trailer tail on your trailer?
I worked for a bakery 10 years ago and talked about delivering bread in my Forester--after I replaced the head gasket.
Old 03-13-2025, 11:55 AM   #15 (permalink)
' trailer tail'
Originally Posted by Andyinchville1 View Post
HI,
* The 'Trailer Tail' differs from a box-cavity in that:
- its sides are angled rather than 'stepped.'
- the enclosed volume is exposed to 'leakage.'
- it, as mentioned, does not span the entire vertical distance ( volume ), from roof-to-belly, as in some box-cavities reported.
* A 'junkyard' Trailer Tail would be 'way out ahead of nothing' ( Robert Parsons ).
* Fabricating something from 'scratch' would likely exceed the performance of the Trailer Tail.
* The original box-cavity, by Continuum Dynamics, DARPA small business administration grant, tested at NASA Ames, Palo Alto, California.
* Smoke flow imaging of Golf-I at Volkswagen reveals the wake drag your tail will be fighting.
* NASA boat tail, 1980
* NASA boat tail, Space Shuttle, 1977, ( note, 'bottom' of tail is compromised
due to large angle-of-attack tail-dragging prevention requirement of delta wing vortex-lift at landing, not a constraint for 'ecomodders' on the road.
Andyinchville1 (03-13-2025)
Old 03-22-2025, 04:27 PM   #16 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Andy:
Aside from considering the boat tail / trailer tail / boxed cavity in the back, have you considered the managing the airflow underneath? From what I recall seeing on these Sprinters, the underbody tends to be a bit unruly. That unruliness tends to offer a lot of attachment points (e.g. the cross members). Addressing the underbody air flow could give some improvement while also having no impact on loading/unloading.
It probably wouldn't give as much benefit as a good tail, though a combination of underbody management and tail should be better than a tail alone.
The Following 2 Users Say Thank You to NachtRitter For This Useful Post:
aerohead (03-24-2025), freebeard (03-23-2025)
Old 03-24-2025, 01:11 PM   #17 (permalink)
' airflow underneath '
NASA's semi-trailer full belly pan provided a crosswind-averaged 5% drag reduction.
