Old 09-17-2016, 06:51 PM   #41 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Why use an alternator at all?
Use an old magneto with a modern wide range dc controller then you could current limit allowing your deep cycle to charge and discharge depending on available output.
The Following User Says Thank You to rmay635703 For This Useful Post:
MPGeo (09-17-2016)
Old 09-17-2016, 07:31 PM   #42 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I gave up on my turbo home built turbo/generator. It was going to be a part of my turbo compound system but the back pressure was to much when the alternator went into higher loads based on my turbo compound calculator.
So I decided to wait for F1 to release the MGUH technology in about 5 years and then just by one.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MPGeo (09-17-2016)
Old 09-18-2016, 02:03 AM   #43 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
Lightbulb
Gears that withstand 100,000 rpms are not garden variety.
Nothing wrong with solar.
Problem with the always dead on arrival idea of a "turbo alternator" is finding a gear box that is tiny and can accept an input speed of 50,000 to 100,000 RPM.
Agreed.
And although solar has is own challenges to overcome, it is doable.
But as far as the turbonator... I'm still keeping the dream alive way back there somewhere just in case I ever come across something new that might make this feasible.
ZerohourGood luck with your project, keep us posted.
Old 01-16-2017, 12:07 PM   #44 (permalink)
New member, registered to post here.
Why not use a large RC permanent magnet motor (rated upto +200k rpms), remove the and compressor side of the turbo, and instead, machine a coupler on to join the turbine shaft to the motor. Then pass this through a DC - DC converter to 14.4v to charge the battery.
Maybe this + a controller that only enables the existing alternator to activate whilst braking (to act as a supplement charger)= maximum efficiency.
Maybe try negate some of the increased backpressure/reduced flow casued by an additional turbine by removing a muffler or two, as turbine itself acts as a damper for sound anyway.
Old 01-16-2017, 04:53 PM   #45 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
More research
http://ecomodder.com/forum/showthrea...tml#post529153
This one has some insight into making this feasible.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 01-16-2017, 06:42 PM   #46 (permalink)
teoman's Avatar
A3 - '12 Audi A3
This motor can turn at 50k rpm.
Witha few diodes you can change it out to a dc voltage.
It can be a driect drive generator.
Hobbywing Water cooled brushless motor ESC with water cooling jacket hobbywing Neptune series 2040SL 4800KV ship-in Parts & Accessories from Toys & Hobbies on Aliexpress.com | Alibaba Group
Damn! Just had a look at the other thread and the exact same idea was already is being discussed.
Old 01-17-2017, 10:45 AM   #47 (permalink)
Only very large turbo chargers stay under 50,000rpm.
Old 12-30-2017, 09:13 PM   #48 (permalink)
I would focus on or similar alternators used in steam powered generation attached to a couple turbochargers.
Google Wrightspeed. Wrightspeed is building a microturbine generartor range extender for large trucks.
I still have not found anyone reselling one yet. Their website states they do not resell to the public.
Dellta Motorsprts are also playing with the idea calling it mitre microturbine generator
Old 12-30-2017, 11:45 PM   #49 (permalink)
Considering how turbine engines fitted to aircraft work, with their own generators coupled to them (and in some applications an all-electric starter-generator instead of the pneumatic starter separated from the generator which became mainstream in large commercial aircraft), the idea of a turbocharger-driven alternator doesn't seem so unconceivable at all. I'm sure upcoming advances in the usage of materials with greater thermal insulation properties such as ceramic compounds are likely to decrease the possibility of heat damage to the magnets.
Old 12-31-2017, 03:04 PM   #50 (permalink)
I also found MTT Micro Turbine Technology BV that is building a high speed turbine generator for large home or small business use. It seems that there will be many of options soon. I really want to find one as a range extender for an ev pickup truck.
