Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 06-13-2013, 08:41 PM   #1 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
The Ultrasonic Transducer Water Vaporizer
http://www.lawbright.com/energy/
Old 06-13-2013, 08:59 PM   #2 (permalink)
I'd think you'd want facts more than opinions?
http://www.atsdr.cdc.gov/toxprofiles/tp72-c3.pdf
Doesn't list water as an ingredient or being present, but it does mention water insolubility.
https://www.google.com/#safe=off&scl...w=1280&bih=699
Of course in gasoline/ethanol blends some small amount of water is soluable.
I suspect the air itself carries more water to the combustion chamber than the fuel.
There are known benefits for introducing some water or water vapor to an engine- funny I see no performance claims in the quote. I wouldn't spend that amount of money on it for sure.
Old 06-13-2013, 08:59 PM   #3 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
removed wall of text.
Old 06-13-2013, 09:05 PM   #4 (permalink)
There is not enough time to normally convert more than 10% of the fuel into vapor. So the remainder gets cooked within the combustion chamber, to form carbonous deposits within the engine, or gets sent out through the exhaust. That leaves around 90% of the fuel basically wasted.
Looks like crap to me so I didn't read any further. Unicorning here we come.
P.S. Skimmed it a lil... saw magnets and efies... tell your friend to run run run!!! Send it back ASAP, get a refund, and don't look back.
Old 06-13-2013, 09:07 PM   #5 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
The first mod I listed is claiming 20% improvement I believe. And yes I do want educated opinions/facts about what I'm posting. A friend of mine has already spent money on them and might still be able to get his money back
Old 06-13-2013, 09:16 PM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Are you trying to spam EcoModder.com with this thing, OP? Why not post a link to the voluminous amount of text, instead?
Old 06-13-2013, 09:30 PM   #7 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
fixed
link provided ^
The Following User Says Thank You to mikeyjd For This Useful Post:
t vago (06-13-2013)
Old 06-14-2013, 11:58 AM   #8 (permalink)
I wont believe claims like that because fuels that naturally offer 100% vaporization by being super heated at room temperature when under 1atm of pressure like propane or natural gas only offer a slight MPG advantage (some where around 3% to 5%)over gasoline when compairing BTUs/mile.
That should give you your answer right there.
Old 06-14-2013, 01:47 PM   #9 (permalink)
They all appear to be exceedingly efficient ways to separate the consumer from his money.
NFG at anything else, though.
-soD
Old 06-14-2013, 10:29 PM   #10 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
-soD
well put ^
