Old 12-11-2009, 09:35 PM   This thread is in the EcoModder Project Library | #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
under belly pan for 02 Q45
(edited on may 2012 on page 7)
EDITED 12-16-09:
Before you start this project let me make some suggestions:
1. get you car up in the air before you ever start. find some out of the way shop with a lift and ask if you can buy 1 hour of time. Believe me, it will be the best $20-40 you''l spend
when you have it up, take measuremets. coroplast is 4 ft x 8 ft which allows you to lay large single sheets. Figure out mounting points.
take pictures from the ground up. onlt take closeups for detail. A faraway9from the ground level helps peek it all in perspective.
2.some have used wood as mounting points. others use aluminuum straps. I have used aluminuum angle for some of my bracing.
3. try to install using the same lift. it will cut your time in half (probably more) crawling around is a major time consumption
4. have a red or green perm marker to mark measurenent points .
5. buy more suppliies than you'll need...keep you reciept and return
6. when intalling have cheap duct tape from dollar store to test hold things in place before you start drilling holes all over!!!
i.spent the morning measuring and cutting cardboard templets. THen went out to get coroplast and supplies. They had yellow 5ft x 2 ft scraps so I also got 2 sheets of yellow 4 x 8.
The 2011 Audi A8 is my insperation and so I knew I wanted to do a color!
The Following 3 Users Say Thank You to mcrews For This Useful Post:
aerohead (12-12-2009), landsailor (06-21-2011), UltArc (06-08-2012)
Old 12-11-2009, 10:43 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mcrews -
Yay! Looking forward to seeing what you build.
CarloSW2
American Solar Energy Society
Old 12-12-2009, 10:38 PM   #3 (permalink)
mcrews's Avatar
i started in the rear.
I wanted to use one piece of the scrap. It's a solid piece. no ribs. Had to allow for the exhaust that drops below the flat line. I used a a/c vent screen to compensate.
also in the center of the IMPUL bumper at the bottom there is a ressession. I left this open. some place for the air that gets trapped above the pan to escape.
having the rear mufflers lifted would cost $60.
templet
setting up mesh screen
rear vent
where are the elfs when you need them
The Following 2 Users Say Thank You to mcrews For This Useful Post:
beluga (01-02-2014), mjboks (12-14-2009)
Old 12-12-2009, 11:54 PM   #4 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
What method did you use to attach it to the car?
Old 12-13-2009, 12:31 AM   #5 (permalink)
mcrews's Avatar
Sean
The IMPUL bumpers have pretty decent lips that curve under, so I have attached it there.
The at the rear of the sheet is a piece of alumminun angle bar that runs the width. that's the shiny edge. I only needed on support strap at the middle of the alum.
Old 12-13-2009, 12:38 AM   #6 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
So is it just resting in there? Or is the plastic itself bolted on?
Old 12-13-2009, 12:58 AM   #7 (permalink)
mcrews's Avatar
once i start the next section, I'll decide how to finally atach it. I really think that 2 screws will do. the material is pretty sturdy.
Old 12-13-2009, 09:53 PM   #8 (permalink)
mcrews's Avatar
Wow....'this is not easy'! First it rained and was cold and I'm working in a carport. After I got back from church I got started then changed directions....had to call my daughter to run by Home depot....3 hours later.....night time sets in at 5:30....must have crawled under the car 100 times......
I only got the rear axle. Was trying to use one piece (59inches) for the twin mufflers and dual pipes.....not going to work......gonna have to leave split the sheet and go with mesh down the middle.
I'm using 1x2 wood to create mounting points so that the pan is 'level'.
a lift would be nice.......
COcyclist (12-29-2009), richeaston (12-08-2011)
Old 12-14-2009, 03:46 PM   #9 (permalink)
Looks good.
Is that tape that you are using to hold the panels up? If yes, better switch immediately to a different mounting method or you'll lose these panels on the road.
Tie straps or wire are better ways to keep the coroplast attached.
Old 12-14-2009, 08:36 PM   #10 (permalink)
mcrews's Avatar
Originally Posted by Alex99 View Post
Looks good.
I bought some wood screws with large washers that I'm using.
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
