Old 05-10-2010, 07:26 PM   #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Underbody Flow Simulation Images
Interesting simulations of underbody flows
Drag Reduction
One of the most important areas of work is drag reduction. Rieter uses Harpoon to help with this. A production car with two different underfloors (see images above), were compared. A drag reduction of 10% (Cd 0.33 to 0.30) was discovered using Harpoon with a new, flatter underbody concept.
Harpoon speeds up CFD analysis at Rieter Automotive
Underbody Streamlines for Cd = 0.33 (floor 1)
Underbody Streamlines for Cd = 0.30 (floor 2)
Underbody turbulent kinetic energy for Cd = 0.33 (floor 1)
Underbody turbulent kinetic energy for Cd = 0.30 (floor 2)
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following 7 Users Say Thank You to orange4boy For This Useful Post:
aerohead (05-11-2010), ChrstphrR (05-10-2010), COcyclist (05-11-2010), landsailor (08-22-2010), Piwoslaw (05-11-2010), tim3058 (05-11-2010), vtec-e (05-11-2010)
Old 05-10-2010, 09:56 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I'm looking at this image and asking myself where the tire deflectors should go. This particular (probably fictious) car has net outward flow behind its front wheels, so a boattail behind each wheel should be angled accordingly.
At the rear, the picture is less clear, but I think the fairings need to point somewhat inwards. Hmm... tuft test before you add wheel fairings.
Old 05-10-2010, 11:51 PM   #3 (permalink)
Those flow lines do not agree with the Hucho wind tunnel photo of the Calibra, which shows smoke trail flowing obliquely outboard under the nose.
Best to do tuft testing of your car on a normal road, recorded by minicam plugged into a laptop.
Old 05-11-2010, 01:42 PM   #4 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
i'm not sure how to read these images, but if these lines represent the path of air mollecules than the drawing only illustrates the path off a portion of the air that would hit the car, so air outside of these lines will likely form an even bigger wake outside of the wheels than what's illustrated.
so air that starts directly in front of the tires seems to need to go round the outside. that might also be what you see in the calibra image.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 05-11-2010, 05:59 PM   #5 (permalink)
pressure?
Do the different colors connote 'isobars' of differing pressure,rather than the actual stream flow?
Old 05-11-2010, 10:05 PM   #6 (permalink)
tim3058's Avatar
Silver Bullet - '86 Chevy Camaro Z28
90 day: 19.74 mpg (US)
New Blue - '96 Chevrolet Camaro Z28
90 day: 20.46 mpg (US)
Diesel - '96 Chevrolet Tahoe LS
Last 3: 13.56 mpg (US)
Tahoe #2 - '95 Chevrolet Tahoe LS
90 day: 13.05 mpg (US)
SuperDuty - '08 Ford F-350 dually Lariat
90 day: 9.34 mpg (US)
Fundai - '09 Hyundai Elantra
90 day: 26.45 mpg (US)
HRV - '17 Honda HRV LX
90 day: 31.39 mpg (US)
Per the following link to NASA: Definition of Streamlines it appears the streamline pics show the path of the air molecules themselves. Pretty neat information right there, thanks for posting it orange4boy
The Following User Says Thank You to tim3058 For This Useful Post:
aerohead (05-13-2010)
Old 05-12-2010, 05:17 AM   #7 (permalink)
if the paths do illustrate the air molecules than i assume the colors are the speed, with red being fast, and blue slow. looking at the first two images the biggest image i see is illustration 2 has faster moving air underneath the front of the car. the bigest improvement that can be made to most underbody is installing a front undertray and often this is combined with the deletion or reduction of the central airdam on production cars (i've seen this mentioned with the calibra for the first time)and ie most low drag mercs all have this too. this site (in german) has quite some interesting data on the developement along with the image that shows the wake of the front tires
so making air move faster under the car appears to be a good thing based on my interpretation of this data.
Do you mean a boattail that would support this flow direction? if so you're assuming this ourward flow is a good thing, however is causes the air to slow down... what would happen if two partial "side skirts" (or boattails) where placed behind and on the inside of the front wheels crating a duct and preventing the air from moving out. if the air can't move out it can only move backwards so it's speed will remain relatively high and the pressure low. this would stabilise the car in the first place, but also as the low pressure behind the wheels isn't "fed" with air from underneath the car, it might pull in air from the side of the car, thus decreasing the wake. dams in front of the rear wheels designed to guide air under the car might further help decrease the wake.
Old 05-12-2010, 11:43 AM   #8 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Side Skirts
I added side skirts attached to the rocker panels and small dams in front of the rear tires last spring. My fuel log seems to show an improvement in mpg. From what I have read, it is better to keep air under the car flowing backward to help fill in the trailing wake.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 05-13-2010, 11:26 AM   #9 (permalink)
In that case, flow fences should work well.
These could be made with 4" square PVC roof gutter drain pipe, cut diagonally corner to corner, to make 2 L shaped pieces. Then use those to clamp and secure the Coroplast sheeting to the underbody.
These could feed the diffuser vanes at the rear, or just act as long diffuser vanes going front to rear.
Such 4" square PVC drain pipe might make pretty good rocker skirts, too. Cheap. light, easy to work with, easy to find at Home Depot, etc..
However, another school of thought holds that undercar flow spreads laterally and such dispersal means less air under the car dragging against the underbody and giving the car unwanted lift. In that case, maybe it's best to use the flow fences to channel the undercar air obliquely out the sides.
Probably best to apply undertray, then tuft test to video actual airflow patterns at highway speed, then install wheel fairings/strakes at whatever orientations best enhance the flow.
Thoughts?
Old 05-13-2010, 05:13 PM   #10 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
Thoughts?
I guess that would depend on whether the main goal is to reduce lift at racing speeds or to reduce drag and lift at highway speeds. I think in my case a smooth underbody that angles upward to the rear of the car can act as a diffuser to help fill the wake and reduce lift. Basjoos uses inner and outer fences between the front and rear wheels to reduce turbulence from the tires. It's hard to argue with his results. I hope to test this myself as soon as I get a free weekend.
TDi=fast frugal fun
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 10:43 AM
Active Flow Control trebuchet03 Aerodynamics 14 04-07-2012 02:02 PM
FLOW-IMAGES ( brain food - various wind tunnel, tuft testing, smoke trace images) aerohead Aerodynamics 32 02-11-2012 04:13 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
