Old 03-26-2010, 04:27 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Underbody panel testing
I found this in Piechna's book. Sardou ([1]) tested underbody panel configurations on the same car in different wind tunnels, both and without a moving floor.
The chart below shows how adding different underbody panels influences aerodynamic drag and lift, but also lift for the front and rear axles.
Worth noting are two things:
  1. Adding panel #1 down the center increases drag,
  2. Adding the center panels (#'s 3, 2, and 1) decreases lift in the rear.
[1] Sardou M., The Sensitivity of Wind-Tunnel Data to a High-Speed Moving Ground for Different Types of Road Vehicles, SAE 880246, 1988.
ID:	5857   Click image for larger version
The Following 12 Users Say Thank You to Piwoslaw For This Useful Post:
aerohead (03-26-2010), AeroModder (03-26-2010), Bicycle Bob (03-27-2010), Cd (03-29-2010), jime57 (03-26-2010), landsailor (06-19-2012), mcrews (03-26-2010), moonmonkey (03-27-2010), Nevyn (03-30-2010), rbrowning (03-27-2010), TEiN (06-17-2012), whatmaycome14 (07-27-2014)
Old 03-26-2010, 05:40 PM   #2 (permalink)
diffuser
kinda wish they had re-evaluated diffusers to see if there was agreement there.
Looks like a good book.Thanks!
Old 03-27-2010, 12:13 PM   #3 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
tunnel
so from that chart,, pan everything,front and rear but leave the middle of the car unpanned ,,except the middle sides? . wonder if you just pan front to rear but leave the whole middle alone? very interesting. also shows how much pans can drop cd,, thanks for the great info.
Old 03-29-2010, 11:55 AM   #4 (permalink)
I bet the middle one increased drag because with all the panels in place the air entering the engine compartment through the grille didn't have enough room to escape so the whole engine compartment became a "parachute"
Work From Home mod has saved more fuel than everything else put together.
The Following User Says Thank You to shovel For This Useful Post:
Piwoslaw (03-29-2010)
Old 03-29-2010, 12:24 PM   #5 (permalink)
The SHOW - '95 Ford SHO Taurus
We STILL have accept that this info from the tests could be completely different with a different car!
Brian
Old 03-29-2010, 12:54 PM   #6 (permalink)
aero guerrilla
Piwoslaw's Avatar
That sounds like a good explaination.
Nothing a grille block can't partially fix
Old 03-29-2010, 06:16 PM   #7 (permalink)
MaxHedrm's Avatar
Golf TDI - '10 Volkswagen Golf TDI
90 day: 37.69 mpg (US)
The amount of drag increase from panel 1 is negligible compared to the reduction in rear lift. Though the increase in front lift does support the underhood parachute hypothesis.
Driven: 2010 VW Golf TDI
Driven less: 2001 Audi TT Roadster (225)
Parked: 1982 VW Jetta Diesel
Old 03-29-2010, 07:18 PM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I think it's amazing that the panels reduced Cd from 0.30 to 0.27.
I will emulate Sardou in starting my underbody paneling at the rear of the car.
Old 03-29-2010, 10:26 PM   #9 (permalink)
OurInsight - '06 Honda Insight
Gazing at my own Insight, it would seem that panel #5 is the only area not covered, though Honda's design may differ slightly.
I also looked carefully at the rear area. By integrating the cargo well floor with the the bumper cover, even the #5 area is somewhat covered. It does look to me like there is adequate clearance on the torsion beam rear axel to use one large coroplast sheet to cover up everything remaining open, but JMO. I seriously doubt that this improvement will be measurable.
Old 03-30-2010, 05:05 AM   #10 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
the drag resuls are pretty much as expected. while details may vary a full belly pan seems to decrease drag and lift.
what i find strange is the increase in lift caused by the front and rear pannel, and than the spectacular decrease caused by the center pannels.
i wish they'd tested them separately, because the numbers seem to sugest while they only cause a minor decrease in drag they cause a decrease in lift large enough to cancle out the front and rear increase... but one cannot conclude if they do this on their own or together with the first pannels.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following User Says Thank You to lunarhighway For This Useful Post:
DawidvC (02-03-2011)
How to properly test modifications (AKA: don't believe every MPG claim you read) MetroMPG EcoModding Central 123 09-28-2024 06:14 PM
Honda Insight Under-body Smoothing Panels (custom belly pan / undertray) 3-Wheeler Aerodynamics 81 03-30-2018 09:44 AM
Difficulties in Effective A-B-A Testing of Insight 1 jime57 Aerodynamics 29 03-07-2010 07:02 PM
Cheap sheet metal for underbody panel work? Cheapest possible plz! blackjackel Aerodynamics 10 09-27-2009 05:42 AM
