10-30-2017, 08:24 PM | #666 (permalink) |
Changfa diesel + Suzuki
Happy Halloween!
- ~CrazyJerry - Last edited by changzuki; 08-03-2018 at 09:58 PM.. |
The Following User Says Thank You to changzuki For This Useful Post: | Gasoline Fumes (10-31-2017) |
11-19-2017, 05:57 PM | #667 (permalink) |
Addressing the original Centurion's charging system.
Somewhere along the line, the wires connecting original Kubota dynamo to the rest of the car's electrical system were removed. - - - In the hunt for these wires, it was also noted that the dynamo's voltage regulator was also missing. - - - Using Kubota's factory wiring diagram, it was fairly easy to make a new wiring whip and connect it with the new voltage regulator. - The story continues.... - ~CrazyJerry~ - Last edited by changzuki; 08-03-2018 at 09:59 PM.. |
12-06-2017, 06:37 PM | #668 (permalink) |
-Centurion's oil filter- - In the previous posts, the external water pump (and hardware) was removed for replacement. During this time it was discovered the original oil filter was still intact. With this easy access replacement of the original Kubota oil filter was next on the list but it was not without it's own little challenge! - - The auto parts store had a valid part number for a Fram oil filter replacement. Next to the original Kubota filter there is a small height difference - but it's enough to cause a problem - once installed, the filter contacts the shock tower. - - - Back to the auto parts and this time I brought the original filter and spent some time comparing it to the ones on the shelf. - Luckily a cheap Purolator was stocked and fit perfectly! - - - - New oil and filter... onward ho! - ~CrazyJerry~ - Last edited by changzuki; 08-03-2018 at 09:59 PM.. |
12-27-2017, 06:56 PM | #670 (permalink) |
The electrical system on the original Centurion needs attention.
- - - First on the list was a new ignition switch which is made exactly by Kubota as the original Centurion has. Easy peasy.. - - - Second was a bit more challenging. No lights, etc.... So all the rocker switches were removed, disassembled, and contacts sanded with 1500 grit paper. - - - - Now all the lights, etc, work. One of the strip lights added from the "Total Recall" movie still have a couple bulbs working. - - - - - Now that the dash lights work it's easy to see that the gauges are all foggy from the inside of the lenses and will need to be either disassembled and cleaned or replaced... - - - ~CrazyJerry~ Last edited by changzuki; 08-03-2018 at 10:00 PM.. |
The Following User Says Thank You to changzuki For This Useful Post: | nemo (12-29-2017) |
