Old 02-15-2014, 04:29 PM   #11 (permalink)
That is an interesting start.
Originally Posted by maxc View Post
Here is my fuel vaporizer. Needs more work,money,time, project on hold.
Please give us a quick rundown of your design and thinking. There are many folks on here who would be willing to help out.
There are also many who are quite critical. But, if you design and build with good science in mind, they usually go away and leave you alone.
I'll start the questions off with:
Are you attempting to completely vaporize the gasoline?
Are you attempting to thermally "crack" the fuel chains?
Thanks for your contribution to this thread.
Old 02-15-2014, 05:30 PM   #12 (permalink)
Both. Small fragment burn at start up. Then use exhaust heat for vaporization.(need too weld the cat in a enclosure still). Control systems work like a waste oil burner or high eff furnace. The converters always been at the wrong end of the engine LOL. Its not an attempt that's what convertors do
Old 02-15-2014, 05:57 PM   #13 (permalink)
vortex vapor carb
Login • Speed Talk dyno test vortex carb thread.
Old 02-15-2014, 09:56 PM   #14 (permalink)
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
have to be a member to read the thread...
Old 02-16-2014, 06:57 AM   #15 (permalink)
Report this postReply with quoteRe: vortex carb test
by maxc » Sat Feb 15, 2014 7:44 pm
MadBill wrote:
The first sheet speaks of fuel usage in gallons per min. but on the dyno sheets (best I can tell) flow is gal. per 30 sec., so to convert to lb./hr, multiply by the fuel mass per gallon (~6) and then by 3600/30. Then to get the standard B.S.F.C., divide this result by the power at each RPM. e.g. at 3500 RPM the 'Werner' system uses 0.058 gal/30 sec to make 115 HP, so [0.058 x 6 x (3600/30)]/115 = 42.76/115 = 0.363 lb./HP/hr.
At the same RPM, the Rochester carb uses 0.088 gal/30 sec, but makes 135 HP, so the B.S.F.C. is 0.469., thus the Werner used only 0.363/0.469 or 77.3 % as much fuel.
Thanks Bill. Not to bad for no other mods.maxc
Member
Old 02-16-2014, 12:07 PM   #16 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Do you have more information on the engine itself etc.?
I registered but now I'm waiting for admin authorization.
Pressure Gradient Force
The Positive Side of the Number Line
Old 02-16-2014, 12:56 PM   #17 (permalink)
cold vapor carb
It would pass smog test for 1988. It had primative fuel metering.
ID:	14637   Click image for larger version
Name:	carb 4 (2).jpg
ID:	14640   Click image for larger version
Name:	carb test (2).jpg
Old 05-21-2017, 08:23 PM   #18 (permalink)
Very interesting.
Go to 6:46 in the video.
We need more info.
A lot more info...
Old 05-23-2017, 12:43 PM   #19 (permalink)
Found him.
Looks like he has a long way to go...
100MPGmotors.com
