07-21-2008, 05:40 AM
#11 (permalink)
Future EV Owner
I finished the experiment, and I must say I'm pretty excited. I did 6 runs from Hartland (H) to Oconomowoc (O), WI on Hwy 16. I had originally planed an additional 6 runs which would have been on the return trip from O to H, but the cops pulled me over on the return route the first time, so I abandoned that aspect of the testing because they were all over me on each return trip.
Here are the results in the order in which they occurred in A-B-A-B-A-B pattern, where "A" is a test with the fan turned up to its highest setting and the two light holes open and "B" is a test with the fan turned up to its highest setting and the two light holes covered up with tape.
Results:
A1: 50.3 mpg
B1: 49.6
A2: 50:1
B2: 50:0
A3: 50:2
B3: 49:9
A couple of notes:.
The stats on the Scanguage were reset at the same specific points (road signs) at the beginning of each run. Resulting stats were recorded at the same specific points (road signs) at the end of each run. The car was up to speed (50 mph each time) and set on cruise at least a quarter of a mile before the beginning of each run. On the "B" runs the taped holes were checked to make sure they were still covered at the end of each run.
This experiment took place between 1:30 AM and 4:00 AM CST. I stayed in the right lane at all times, except where the road narrowed to one lane, due to construction. I kept the radio off and did not use the wipers, so the headlights and the fan were the only devices I had on.
The engine fan was running quite a bit throughout the test. It was a variable that I could not control. Normally I would turn the heat up just a bit to reduce the water temperature, but I couldn't do it because I was testing. However, I do want to add that under normal conditions turning the heat on just a little keeps the water temp below 206 degrees, where the fan normally turns on. And with that much air flowing, the temp change in the cabin is hardly noticeable.
Weather:
The road was totally dry.
UV Index: 0 Low
Wind: From WSW at 5 mph
Humidity: 95%
Pressure: 29.89 in.
Dew Point: 68°F
Visibility: 9.0 miles
Final comments:
I may do more experiments once the guilt of wasting all that gas and ruining by mileage by driving without hypermiling wears off. I'm looking forward to others trying this out.
07-21-2008, 05:54 AM
#12 (permalink)
Future EV Owner
One more thing: I drove each return trip from the end of each test to the beginning of the next test with the fans off. I didn't smell anything, which is what I expected. If the high pressure is in the front of the car and the low pressure is in the back, the air will tend to flow to the back of the car and out the holes. Of course, the car isn't always moving, so that is always a concern - hence the fans staying on.
07-21-2008, 08:01 AM
#13 (permalink)
I wouldn't worry about CO much. First off it takes a lot of it to do damage, and second is that modern cars emit very little of it. Carbed cars were a lot worse. You'd get a killer headache before anything happened.
07-21-2008, 12:17 PM
#14 (permalink)
An interesting, but not convincing, set of observations. They do trend in the desired direction, which is good. However, in terms of experimental design there are two problems. (These are common problems in this sort of test, I'm not singling you out.)
1. The data is limited. The means differ by .37 mpg but that is not much different than the variation within the measurements, so we can't say with much confidence yet if it the measured difference is statistically significant.
2. You knew the state of the car for each test, which opens up the possibility of subconscious changes in driving style which could bias the results. If you do repeat the experiment it would be good if you could have somebody else flip a coin before each run and then open or close holes without telling you which they did. You can determine which it was at the end of the run.
I'm still skeptical - it doesn't seem right that the tiny amount of air coming out of those two small holes could significantly affect the large and continuously generated volume of low pressure air behind the car.
07-21-2008, 04:52 PM
#15 (permalink)
Future EV Owner
Originally Posted by pasadena_commut
An interesting, but not convincing, set of observations....
I didn't have time to compute whether or not it is statistically significant yet. Given the trajectory, a few more samples would easily make the difference.
Blind studies are not reasonable in this situation. In fact, if you only trust blind studies, all posts on this forum are useless to you. This information is made public for others to think about, test for themselves, and possibly design better and safer solutions. I will be doing that myself, too.
Although my background is in experimental psychology, I spend my free time messing with tangential bypass vacuums. I know from experience that a small leak in the system affects waterlift in ways that seem disproportionate. I'm used to dealing with enclosed systems where air dynamics don't play much of a role in a system that is designed for larger volumes of air than are actually used, so I didn't exactly know what to expect in this situation. The results of this test, then, are in line with my experiences with enclosed systems involving waterlift.
07-21-2008, 06:37 PM
#16 (permalink)
Yours was one of the few experiments here that would be easy to blind since the modification was small and isn't visible from the driver's seat.
I'm used to dealing with enclosed systems where air dynamics don't play much of a role in a system that is designed for larger volumes of are than are actually used, so I didn't exactly know what to expect in this situation. The results of this test, then, are in line with my experiences with enclosed systems involving waterlift.
I'm not saying it isn't possible - nobody can solve the air flow equations so there could be all sorts of surprises. It just doesn't seem likely to me that a small amount of air blown into the one to several cubic meter trailing low pressure region would do much.
I did think of another possibility. When the cabin is sealed the fan is pushing air into a closed space so the internal pressure of the car goes up. When you unplug the two back holes you reduce the cabin pressure by some amount, and the fan doesn't have to work as hard to move air into the cabin. So it draws less current, so the alternator is on less to provide that current, so the MPG goes up slightly compared to the "fan on, holes closed" case because the engine is loaded less. This may actually be a a gas saving technique (albeit a small one) via a mechanism that has nothing to do with the car's aerodynamics. If this hypothesis is correct plugging the back holes and slightly cracking a back window should give some FE improvement too. We've all seen the A/C versus windows open arguments, but I do not recall anybody measuring fan +/- windows open.
07-21-2008, 06:50 PM
#17 (permalink)
Future EV Owner
If you have the resources to do blind studies (not to mention double-blind studies), then please do so. I suspect, however, that you will say that you don't have the time. That's what I meant.
Frankly, in these situations blind studies aren't done. Popular Mechanics, Consumer Reports, Car and Driver don't do blind studies. They do easily replicable tests and publish their results for people to judge and peers to examine, and possibly retest.
However, if you do have the resources, please test it yourself. Keep in mind that a proper scientific test requires a random sampling of the available population (meaning both cars and drivers). If you can also get a dust-free wind tunnel, then that's even better. Keep us updated on your progress.
