02-20-2008, 11:13 PM
#11 (permalink)
arg! for some reason I can't edit my last post to fix the photo, so here it is!
02-21-2008, 11:20 AM
#12 (permalink)
lookit all d rabbits, they're multiplying like.............rabbits
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
03-17-2008, 01:18 PM
#13 (permalink)
Originally Posted by Ryland
I have a 1982 VW Rabbit Diesel non turbo that is for sale, it needs a front wheel bearing ($100) and brakes all around ($150), but has a solid body, and good engine, it could have a turbo added, altho it would need a different injector pump with a turbo, was bought new by my grandparents and was taken in for service by the dealer any time the mpg droped below 50mpg.
VW didn't start useing turbos untill 1984, and I don't think it was standard untill I think the early 1990's.
Actually, these engines will take a later indirect injection 1.6L turbo exhaust manifold, turbo and intake manifold directly from an '84 or later TD Jetta or Rabbit/Golf. To get the most out of the turbo you would need to swap in a turbo injector pump, but turning up the fuel quantity on the NA pump will get you a 5 or 6 more ponies. As it is, the turbo itself can give you a nice little performance and FE boost. The added air under boost gives more 'working fluid' inside the combustion chamber, making the engine a little more volumetrically efficient. There a nice VW Indirect Injection Diesel Forum, where that and many other early VW diesel topics are discussed.
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
03-17-2008, 02:29 PM
#14 (permalink)
thanks for the input Stan,
boost will have to be kept very conservative as the turbo engines for rabbits are purposely of low compression nature. also oiling jets below the pistons are absent in NA models. anyone attempting that should seriously consider an properly sized, well placed (ideally water sprayed) intercooler, but most importantly monitor added heat in the engine via an exhaust gas temperature gauge.
thenafter SLOWLY make adujustments to the wastegate to increase boost.
happy smelting!
1.6l NA '80 Jetta Diesel 70mpg
03-17-2008, 10:49 PM
#15 (permalink)
1984 Volkswagen Jetta Turbo Diesel
how much are you willing to give for a 1984 Volkswagen Jetta Turbo Diesel, it has a new timing belt, clutch, brakes, glow plugs, strut towers, windshield gasket, and head gasket at 107,000, only 146,000 miles. Also no rust, well taken care of.
Email back at kevinlangreck84@hotmail.com
03-17-2008, 11:19 PM
#16 (permalink)
Giant Moving Eco-Wall
depends, how much do you want out of it
03-17-2008, 11:28 PM
#17 (permalink)
Camryaro - '92 Toyota Camry LE V6 90 day: 31.12 mpg (US) Red - '00 Honda Insight Prius - '05 Toyota Prius 3 - '18 Tesla Model 3 90 day: 152.47 mpg (US)
Originally Posted by 3lr
boost will have to be kept very conservative as the turbo engines for rabbits are purposely of low compression nature.!
Do you have a source for this?
03-18-2008, 12:21 AM
#18 (permalink)
happy smelting!
Hmm, my 1980 1.5L NA diesel Rabbit was (IIRC) about 22:1...I wouldn't call that "low compression". As for the squirters and intercooler, those are nice for performance, but wouldn't be needed for someone interested in recreating an ECOdiesel of the early 90's in a first-gen Rabbit. One would also need the turbo-to-pan oil drain line and the oil pan from a TD Jetta or Golf.
That said, I'd be all over this offer if Ryland in my neighborhood.
04-22-2008, 03:22 PM
#19 (permalink)
VW SON
RYLAND's VW Rabbit Diesel
Hey, I'm wondering if your Diesel VW is still available or if anybody else knows where I can get one for a good price....I'm looking to convert to BIODIESEL. Let me know if anybody can help me find one....
10-28-2008, 03:28 AM
#20 (permalink)
i have a running 92 jetta turbo diesel for sale make me an offer
