Old 09-16-2012, 11:49 AM   #11 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
^ A few guys run the TH400 behind them, especially if its just fun street use. The 4L80 is a good option too, and has overdrive.
A few guys I know have d-max powered trucks. The other day was out in a 2007 crew cab 4x4, 38" tall tires with a 4/6" lift, and even that huge truck will ignite the tires at will. With a 5" turbo back exhaust it sounds great too.
Old 09-17-2012, 10:44 AM   #12 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
Excellent idea, and just pour vegtibal oil straight in there
Old 09-17-2012, 11:31 AM   #13 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Bad idea. You go this route, your engine will not last long. You want to run this stuff, get a separate tank, good heat exchanger and start/shut down on real diesel fuel. Cold vegetable oil is a recipe for failure.
I'm not coasting, I'm shifting slowly.
Old 09-17-2012, 11:44 AM   #14 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
6.6 Dirtymax with the Allison six speed Oh and straight pipes to make it sound like a Big Rig
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 09-17-2012, 11:55 AM   #15 (permalink)
2000neon's Avatar
'nuff said! Ha ha. (relatively stock motor)
Old 09-18-2012, 12:30 AM   #16 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Measure for clearance first. The 6.2 & 6.5 GM Diesel are taller and wider. You'll have to relocate the motor mounts up. The oil pan might need some modification too. Had to notch my oil pan in the back to clear the crossmember in my '91 Caprice Wagon 6.2 conversion. With my mounts, I'll bolt them to the engine and set it in loose. Have the motor mounts welded on to the crossmember after the trans is bolted in. It can be done, and if you can find a cheap 6.2 and an overdrive 700R4 or 200R4 it'd be sweet.
VT247
Old 09-18-2012, 04:07 PM   #17 (permalink)
I run a TH700R4 in my 6.5L powered suburban.
Don't have any problems, I also don't do anything stupid with it.
I also run vegetable oil. I cut it in with my diesel fuel at a rate of up to 25% in the summer.
No tanks, fuel warming system, switching valves, or any garbage like that. Just a serries of 3 fuel filters and 2 switchable lift pumps each with their own primary fuel filter.
Old 09-18-2012, 06:08 PM   #18 (permalink)
Jakins's Avatar
I wanted to run That chevelle was wicked! Lmao!!!!!!!!!!
Old 09-19-2012, 08:43 PM   #19 (permalink)
Spdmini's Avatar
SPDwagen - '12 VW JSW TDI DSG
90 day: 35.8 mpg (US)
Your stanadyne pump is hating life, as is every other part of the 6.5. WVO doesn't behave like D2 so I can only imagine what the injectors and pistons look like.
Also, weight should be a consideration. 6bt Cummins is roughly 1000lbs and the Duramax is near 880.
http://ecomodder.com/forum/image.php?type=sigpic&userid=28770&dateline=134810  0039
Old 09-21-2012, 05:22 PM   #20 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
4JG2-T 3.1L or a 4JB1-T 2.8L JDM engine would do nice.
easy install being a RWD 4X2
use the GM diff and gear it as needed.
though it mite take a small body lift for the hood to close LOL
the 4BT cummens is about 750LBs plus trans also commenly red lined at 2,800rpms.
these two isuzu engines are red lined at 4,200 rpms...
all the 2.8s are computer free, early 3.1s with manual trans are computer free also.
about the same power as a stock N\A 6.2L 130hp
the 3.1L is about 130hp the 2.8L is about 105hp
and 550LBs for the engine 125lbs for the trans...
no rocket ship, but it would be cool
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
el camino, idea, small diesel, test
