Old 10-10-2008, 01:35 PM   #1 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
Weight reduction
I've heard that reducing the weight by 10% will increase the fe by 4-5%, does anyone have any data on this? Also, how much luck has anyone had with actually lowering the weight enough to make a difference. My car is around 3500 pounds so I don't know if I can drop 350 pounds out of it, I might try anyway though.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 10-10-2008, 03:26 PM   #2 (permalink)
It's highly duty cycle dependent.
Sort of the inverse of aero.
Weight reduction is most helpful for stop and go.
Aero for cruising speeds.
Rotating weight is even more important for stop and go, but not easily reduced in most cases.
Old 10-10-2008, 03:29 PM   #3 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
This is a drastic step IMO. I would start off with the small stuff first: Inflate your tires properly, tune it up, modify yourself, read up on techniques...
But here is some really really good information on how weight reduction works. It should help you out on what weight to actually reduce for the best benefit.
EDIT: forgot link...http://www.nissanclub.com/forums/200...e-modders.html
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 10-10-2008, 04:04 PM   #4 (permalink)
BKO
bottonavy's Avatar
'06 Toy - '06 Toyota Tundra SR5 4WD Extended cab
90 day: 17.51 mpg (US)
'10 Corolla - '10 Toyota Corrola LE
90 day: 36.38 mpg (US)
I removed the beackseat in my 94 ford aspire.
The junk weighed 40 lbs
The back seat weighed 42.9 lbs total including the rear rug, ashtray, seat belt bottoms, and rear hatch cover. (9.7 lbs)
I totaled the amount and it came to 82.9 lbs .
Hopefully That will help my MPG
Brian
Old 10-10-2008, 06:18 PM   #5 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Weight matters a lot in hilly country where the grade term of the road load equation is not zero.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 10-11-2008, 12:27 PM   #6 (permalink)
wt/mpg
Society of Automotive Engineer research has demonstrated that a 10% wt. reduction would net you an average 3.8% mpg improvement.
Old 10-12-2008, 12:54 PM   #7 (permalink)
In terms of rotating weight (wheels/tires), all else being equal (driving style) how much improvement would there be in FE? I'm looking at at wheel/tire combo that would save 4#/wheel (the more you spend, the lighter the rims, which would take years in FE savings to make up). I know most will talk about the aerodynamic efficiency of the wheels, but I think just having lighter tire/wheels will make the engine strain less both with stop/go and highway driving. The added benefit of improved acceleration/braking and looks is also attractive.
Old 10-12-2008, 01:17 PM   #8 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
An interesting tool can be found there :
Tool for visualizing aero vs rolling resistance - GasSavers.org - Helping You Save at the Pump
or more precisely here : http://www.geocities.com/frontsidesk8er/delsolaero.xls
You can change weight, CRR, CD & FA and see how the consumption (at constant speed) varies. For me a 10% weight reduction would achieve a 3.3% reduction at the speed I drive the most often.
Have fun,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 10-12-2008, 11:37 PM   #9 (permalink)
Taurus - '99 Ford Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Ford Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Kawasaki Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 Suzuki SX4 Technology AWD
90 day: 24.62 mpg (US)
remove everything you deem not necessary from inside the car. seats, carpet, trim, etc thats the free stuff.
if you are a guy who believes in the ends justify the means, you can get lighter tires; lighter rims, lightest ive seen is 12 pounds, replace some or all glass with polycarbonate(lexan); replace ll possible body parts with polyurethane or fiberglass or kevlar; remove the spare, and have AAA handy; switch to lighter racing seats; etc etc, you get my idea. in order to gain 4-5%, you end up spending alot of money, or time for fabrication. you decide.
Old 10-13-2008, 05:03 AM   #10 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
Totally agree. Although you can get the semi-lightweight stuff for relatively cheap if you search hard enough. I'm down 300lbs in my second car from extreme stripping. still rockin' the stock driver seat, still have 25lbs of sound deadener to remove, haven't changed out to a smaller fuel cell, still using glass instead of poly, haven't finished removing dead weight off the front end. I'm sure I have 100lbs more I can remove. I haven't even brought the grinder out to remove random metal.
Note: ^ Not for the average user ^
Weight Reduction AnDoireman EcoModding Central 25 08-14-2022 02:24 PM
Nissan and Toyota's New Year's resolutions: LOSE WEIGHT MetroMPG General Efficiency Discussion 18 01-16-2015 04:57 AM
CRX vtec weight reduction !? chipX EcoModding Central 24 09-05-2008 08:17 AM
weight VS. wind wanna bECO Aerodynamics 15 08-13-2008 02:32 PM
Very thorough article on weight reduction rsx2002 EcoModding Central 11 07-09-2008 11:53 PM
