Old 10-13-2008, 10:40 AM   #11 (permalink)
Fuel is one of the most easily removed weights.
Although adding the amount every day for that day's projected use has some drawbacks. One of which I believe is evaporative emissions from the refueling process, assuming you're using a home supply via fuel cans.
Old 10-13-2008, 11:10 AM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
1) My mileage varies from 59 mpg with a full tank to 62 mpg with an empty tank. 800 daily commute data points are consistent. 10 gallons, 6 lb / gal gas = 60 lb.
-60 lb (2.6%) = +5% mpg
2) On a certain route, with my family on board, I got 56 mpg with ideal conditions yesterday. Compare that to my 63 mpg average on that route, driving solo.
+200 lb (9%) = -11% mpg
Old 10-13-2008, 11:19 AM   #13 (permalink)
Lucille - '93 Saturn SC1
90 day: 33.22 mpg (US)
SportScort - '99 Ford Escort ZX2
It should also be mentioned that the more interior you start pulling out the louder road noise will be. It's obvious but the impact can be quite astonishing. I don't notice my Saturn being any louder than any other car, but my father can barely stand riding in the car. Considering that it still has all the carpet and sound deadening material, it goes to say your mileage may vary.
As almighty said, it's not exactly for the average user.
Old 10-13-2008, 12:28 PM   #14 (permalink)
Not to mention the value of your time, or the fuel burned in making repeated trips to the gas station.
Old 10-13-2008, 06:48 PM   #15 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Would it be a valid weight reduction strategy to pull all the sound deadening material (all of it tends to be heavy stuff) and simply wear noise cancelling headsets?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 10-13-2008, 08:24 PM   #16 (permalink)
You should probably avoid noise canceling headphones while driving.
Old 10-13-2008, 09:22 PM   #17 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by saunders1313 View Post
I've heard that reducing the weight by 10% will increase the fe by 4-5%, does anyone have any data on this? Also, how much luck has anyone had with actually lowering the weight enough to make a difference. My car is around 3500 pounds so I don't know if I can drop 350 pounds out of it, I might try anyway though.
Depends on specifics. Assuming optimal engine efficiency over your route, your car is roughly 4088 square inches which is about 2.64 square meters and supposedly has a drag coefficient of .36. At 3700lbs (200lb driver/stuff) curb it's about 16460 newtons, and assuming a typical rolling resistance of .012 needs ~198N to roll. To move through the air at 55mph or 24.6m/s, ya need, about ~352N. So... since you're at ~550N right now, shaving off 300lbs in a 3700lb car would decrease the force needed by ~3400/3700(198N)+352N=~533N, so your mileage would go up by ~550/533=1.03, aka 3%. Now, the problem is this is assuming the engine is operating at otpimal efficiency, and if it's not, which it tends not to be for most cars, then you'll see less than a 3% gain. Naturally as your average speed drops from 55mph, the gain is greater, and as it rise, it's less. On the other side of the spectrum, if you have 14" wheels available (j-yard?), you could run LRR 14" tires (rolling resistance of ~.008), and gain around 13-14% assuming ideal engine efficiency or less w/o it.
Old 10-13-2008, 09:26 PM   #18 (permalink)
Cops around here frown on headphone use while motoring.
Old 10-13-2008, 11:37 PM   #19 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by almightybmw View Post
I haven't even brought the grinder out to remove random metal.
Note: ^ Not for the average user ^
Just don't go too far: How to get your econobox into the 14's-A must read.
Old 10-14-2008, 02:40 AM   #20 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
Originally Posted by Clev View Post
I love that read. Read it first many years ago, had me rolling. Certainly impressive they dropped so much weight, and gained so little time. 1674lbs from 2762lbs. That is beyond impressive, that's just insane. And gained 2 seconds and 10mph to 14.3 @ 93.2mph. I think I'll stop when the sawzall comes out. Road Rally racing needs some structure beyond the full cage.....
Weight Reduction AnDoireman EcoModding Central 25 08-14-2022 02:24 PM
Nissan and Toyota's New Year's resolutions: LOSE WEIGHT MetroMPG General Efficiency Discussion 18 01-16-2015 04:57 AM
CRX vtec weight reduction !? chipX EcoModding Central 24 09-05-2008 08:17 AM
weight VS. wind wanna bECO Aerodynamics 15 08-13-2008 02:32 PM
Very thorough article on weight reduction rsx2002 EcoModding Central 11 07-09-2008 11:53 PM
