Old 10-31-2012, 09:12 AM   #41 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by Varn View Post
How do you compare fuel usage to distance on a real time basis.
You just need to monitor VSS as well
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 10-31-2012, 09:16 AM   #42 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
So I would need to have a circuit to monitor the speed as well.
My needs are now doubled with the addition of my second pre obd2 diesel vehicle.
Noah Webster, 1787
Old 10-31-2012, 09:19 AM   #43 (permalink)
AndrzejM's Avatar
Yes you need two flow meters and a VSS signal.
Old 10-31-2012, 09:21 AM   #44 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Wow ,thank you for offering.
I will have a motor controlled louver system for my grille, using a headlight motor.
I have two large electric fans with two speeds.
I can get cheap temperature sensors, 0 to 5 volts.
headlight motor has open and closed limit switches already.
I can get a throttle position sensor for reading back louver position, 0 to 5 volts.
I'd like to:
Close louvers when the key is turned on, and temp sensor >.3 volts, for example.
Open louvers to value X when temp reaches 1.0 volts
open louvers to value y when temp reaches 1.5 volts
turn on fan #1 to low when temp exceeds 1.6 volts
turn on fan #2 to low when temp exceeds 1.65 volts
turn on fan #2 to low when Air Conditioning is on and speed switch is off ( I have another component that reads the VSS speed info and can be set with dip switches.)
Progressively switch fan #1 and then fan #2 to high setting based on a combination of temperature and boost value from a pressure sensor.
Allow fan #1 to run on low setting for X minutes after shutdown, depending on underhood temperatures.
Have an LCD display with a few switches, so I can see all these temps and louver values.
Sound simple enough?
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 10-31-2012, 09:28 AM   #45 (permalink)
AndrzejM's Avatar
That is not so complicated to achieve with arduino clone. I would need some time go get it done though. I have very limited free time resources recently and don't know when it will change. But I'll try to help you.
Old 10-31-2012, 09:37 AM   #46 (permalink)
skyking's Avatar
I think it will take a month or so for me to gather the components together. Perhaps I can do some studying, or get some example code from you and expand on it. I am self taught in command line unix/linux and administer several servers, can muddle through in html and PHP, and some mysql. I figure I may get it done myself if I can get some specific example code to expand on.
Of course, the code for the two flow meters and the VSS to get instant and cumulative fuel use will work for all of us. That would be first on the priority list to do and share. I can control my louvers and fans manually forever, if needed.
2003 TDI Beetle
2002 TDI Beetle
Old 10-31-2012, 09:41 AM   #47 (permalink)
Do more with less
Do you think a vacuum/boost gauge would help me monitor economy? I know with a non turbo gas engine keeping a high vacuum is helpful to get better mileage. Not so sure with a turbo diesel.
Noah Webster, 1787
Old 10-31-2012, 09:58 AM   #48 (permalink)
skyking's Avatar
No, diesels really don't benefit from a gauge like that. No throttle plate. All it can tell you is if the air filter is plugged up. My truck has a filter minder for that.
2003 TDI Beetle
2002 TDI Beetle
Old 11-03-2012, 11:59 PM   #49 (permalink)
Futurelec
Originally Posted by skyking View Post
Thanks Billy!
Don't let that link title fool you, it is 2.0 to 30 Liters per hour.
Liters per minute would be worthless, LOL.
I haven't played with the Futurelec units yet, how ever I think the figures for the Bio-Tech units are correct. I've ordered a Futurelec unit to see how well it works on both sides of my Diesel Rabbit
Bill
The Following 2 Users Say Thank You to Hilly-Billy-13 For This Useful Post:
skyking (11-04-2012), Varn (11-04-2012)
Old 11-04-2012, 07:24 AM   #50 (permalink)
skyking's Avatar
It was just the link title that was messed up. It shows liters per hour in the description. That is what I will try on my truck. I don't know if the rabbit return enough to get 2 liters per hour. If it does not return that much, I will buy that one off you.
2003 TDI Beetle
2002 TDI Beetle
