View Poll Results: What PSI are your tires at?
<35 PSI
0 |
0% |
35-40 PSI
22 |
32.84% |
41-45 PSI
19 |
28.36% |
46-50 PSI
11 |
16.42% |
>51 PSI
15 |
22.39% |
10-27-2019, 01:46 PM
What PSI do you run on your tires?
I will be getting new tires for my Jeep so I am wondering what PSI most people go for here without problems.
10-27-2019, 02:00 PM
I run at 40PSI, but marked 41-45PSI, because I didn't want to be considered in the standard pressure group. Who knows, maybe I'll play with 41 to 43PSI.... maybe NOT with late fall & winter coming.....maybe...... ya know?
The Following 2 Users Say Thank You to litesong For This Useful Post:
10-27-2019, 02:28 PM
Don’t worry, you’re not...
10-27-2019, 04:10 PM
Rat Racer
Max sidewall. on my Avid Ascends, that's 51.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 3 Users Say Thank You to Fat Charlie For This Useful Post:
10-27-2019, 08:05 PM
Doesn't that shake your dentures loose?
If'n ya go to New York City, potholes are attracted to high pressure tires.
10-28-2019, 12:15 AM
Max sidewall 50 psi stone cold, they will be well into the 50s when warm.
The Following User Says Thank You to Hersbird For This Useful Post:
10-28-2019, 01:56 AM
Master procastinator
I use 2.8-3.0 bar. What's that, 40-ish PSI?
Also, depending what tires i have at the moment. Some tires are soft&squishy even at 3.5bar, some are fine at 2.5bar
Reason: Forgot something, added that
The Following User Says Thank You to iikhod For This Useful Post:
10-28-2019, 06:27 AM
Master Novice
I cranked it up to max on my Prius shortly after I got it. Ran it like that for a few months but it seemed to cause the headlights to die young so I let them back down to about 40.
Then I replaced most of the lamps with LED and pushed the pressures back up to 51.
I don't know what the differences are between the truck's lamps and the Prius', it doesn't seem to affect them at all. It runs at 45. Any higher, though, and even I start to become unhappy with how the truck rides.
The Following User Says Thank You to elhigh For This Useful Post:
10-28-2019, 08:25 AM
#9 (permalink)
About 3 bar (we have metric air over here) that's a low 40's PSI.
More causes resonances and sounds which make long distance travel tiresome, and afaict hardly helps economy.
10-28-2019, 10:04 AM
#10 (permalink)
Seems like 40 is a good starting point, and a lot of you guys go a lot higher with no issues. Thanks
