View Poll Results: What PSI are your tires at?
<35 PSI 0 0%
35-40 PSI 22 32.84%
41-45 PSI 19 28.36%
46-50 PSI 11 16.42%
>51 PSI 15 22.39%
Voters: 67. You may not vote on this poll
Old 10-27-2019, 01:46 PM   #1 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
What PSI do you run on your tires?
I will be getting new tires for my Jeep so I am wondering what PSI most people go for here without problems.
Old 10-27-2019, 02:00 PM   #2 (permalink)
I run at 40PSI, but marked 41-45PSI, because I didn't want to be considered in the standard pressure group. Who knows, maybe I'll play with 41 to 43PSI.... maybe NOT with late fall & winter coming.....maybe...... ya know?
The Following 2 Users Say Thank You to litesong For This Useful Post:
roosterk0031 (10-28-2019), Taylor95 (10-27-2019)
Old 10-27-2019, 02:28 PM   #3 (permalink)
Don’t worry, you’re not...
Xist (11-19-2019)
Old 10-27-2019, 04:10 PM   #4 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Max sidewall. on my Avid Ascends, that's 51.
Transmission type Efficiency
The Following 3 Users Say Thank You to Fat Charlie For This Useful Post:
Hersbird (10-28-2019), PaleMelanesian (11-20-2019), Taylor95 (10-28-2019)
Old 10-27-2019, 08:05 PM   #5 (permalink)
Doesn't that shake your dentures loose?
If'n ya go to New York City, potholes are attracted to high pressure tires.
Old 10-28-2019, 12:15 AM   #6 (permalink)
Dark Egg - '12 VW Touraeg
Max sidewall 50 psi stone cold, they will be well into the 50s when warm.
The Following User Says Thank You to Hersbird For This Useful Post:
Old 10-28-2019, 01:56 AM   #7 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
I use 2.8-3.0 bar. What's that, 40-ish PSI?
Also, depending what tires i have at the moment. Some tires are soft&squishy even at 3.5bar, some are fine at 2.5bar
Last edited by iikhod; 10-28-2019 at 01:58 AM.. Reason: Forgot something, added that
The Following User Says Thank You to iikhod For This Useful Post:
Old 10-28-2019, 06:27 AM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I cranked it up to max on my Prius shortly after I got it. Ran it like that for a few months but it seemed to cause the headlights to die young so I let them back down to about 40.
Then I replaced most of the lamps with LED and pushed the pressures back up to 51.
I don't know what the differences are between the truck's lamps and the Prius', it doesn't seem to affect them at all. It runs at 45. Any higher, though, and even I start to become unhappy with how the truck rides.
The Following User Says Thank You to elhigh For This Useful Post:
Old 10-28-2019, 08:25 AM   #9 (permalink)
90 day: 55.39 mpg (US)
About 3 bar (we have metric air over here) that's a low 40's PSI.
More causes resonances and sounds which make long distance travel tiresome, and afaict hardly helps economy.
Old 10-28-2019, 10:04 AM   #10 (permalink)
Seems like 40 is a good starting point, and a lot of you guys go a lot higher with no issues. Thanks
