09-15-2014, 08:53 AM
#41 (permalink)
Originally Posted by mcrews
to add to Mech, the spinning weight is 3-4 times more than static weight. SO 5lb at each wheel is 15-20lb.
If we are talking about acceleration, the maximum ratio is 2:1. That happens only when all the added/reduced mass is concentrated at the radius of the wheel. In reality that is not the case and the ratio is less than 2:1. I'd estimate, that 5 lb at wheel is comparable to 7-9 lbs of non-rotating mass.
09-15-2014, 02:35 PM
#42 (permalink)
5 pin sensor
I'm surprised no one has listed light weight lug nuts as a modify action. 4 of them weighing 3.5 lbs a set on 4 wheels can definitely add up. You could also add deleting rear brakes to reduce the rotational mass, that's about 15lbs a wheel
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
09-15-2014, 02:48 PM
#43 (permalink)
Rotational mass is experienced at the edge of the radius, nut the center, so lug nut weight is not consequential.
And I can not imagine removing the rear brake........
09-15-2014, 03:29 PM
#44 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Originally Posted by Chrysler kid
... You could also add deleting rear brakes to reduce the rotational mass, that's about 15lbs a wheel
You aren't seriously suggesting that someone should delete their rear brakes on a road worthy automobile...are you? Not legal or safe.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
09-15-2014, 04:00 PM
#45 (permalink)
Nah, ditch the brakes. All they do is slow you down.
The Following User Says Thank You to Hersbird For This Useful Post:
09-15-2014, 04:11 PM
#46 (permalink)
Who needs a parking brake when you can shoulder it against a rock anyway? :P
Lug nuts don't do much, but if you change the hub material into something space age your wallet will be so much lighter you'd feel it at the pump.
Seriously, has anybody ever looked into the weight of the hub etc?
Why bolt that carbomagnesium rim on a pig iron hub?
Any other way to reduce weight on the hubs, or am I, err.... boring?
09-15-2014, 04:50 PM
#47 (permalink)
Actually, I chuckled at that.
Rocks are so prehistoric! Use other cars to stop yours!
This article is about $15,000 carbon-fiber rims for a Porsche 911, 19x8.5 and 19x12" rims, that are over ten pounds lighter than the stock wheels. One source estimated that would increase fuel efficiency by four percent:
Carbon-Fiber Wheels: A Costly Upgrade, But Better Performance?
09-15-2014, 04:53 PM
#48 (permalink)
How do alloy and aluminum wheels fair in terms of fuel economy?
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
09-15-2014, 05:13 PM
#49 (permalink)
09-15-2014, 05:37 PM
#50 (permalink)
Honda put lightweight alloy wheels on the VX and HX and lightweight aerodynamic wheels on the Insight and Civic hybrid, but many users on here put smooth wheel covers on steel wheels instead of trying to get lightweight ones--general consensus seems to be that aerodynamics make much more of a difference than weight. People say not to purchase new rims expecting to save money.
