Old 03-27-2013, 08:12 PM   #1 (permalink)
blowncopcar's Avatar
Gumby - '97 Geo Metro
90 day: 58.53 mpg (US)
Where did y'all find your kill switches?
Like the title says, where have you guys gotten your actual kill switches from? The push button ones I have I either have to push twice or are closed switches... Now ive been to all the auto parts stores and Lowes. I'm thinking of just going to a toggle switch... Unless you guys think a toggle switch is a bad idea or can tell me where a good open push-button switch is like the ones in the write-ups. Thanks for your help!!
1997 Geo Metro 1.0L 5speed
Pass mirror deleted
Custom molded front bumper with top grill closed and 50%summer-90%winter bottom grill closed+ lowered lip BUMPER IN PICTURE IS NOT BUMPER NOW
Partial kamback (in progress)
Headlight covers molded into bumper
Rear underbody tray (suspension to bumper)
Windows tinted 35% NOT PICTURED
Old 03-27-2013, 10:35 PM   #2 (permalink)
Eco Sol
Shortie771's Avatar
HERE is a great thread with a lot of information about kill switches. You can probably find most, if not all of the things you need to make your own switch at RadioShack or any electronics store. I hope it helps.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 03-27-2013, 11:16 PM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I picked up a "momentary off" switch but haven't installed it yet. It basically opens the circuit when you press it, then reverts back to a closed circuit. In terms of rudimentary hypermiling, it kills the engine and turns the ignition back on for you.
Got mine at Menards. Radio Shack will have them.
Old 03-28-2013, 01:28 AM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Radio Shack.
Old 03-28-2013, 02:47 AM   #5 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
dead microwave in the trash; normally closed micro-switch.
Old 03-28-2013, 07:46 AM   #6 (permalink)
Cyborg ECU
+1
Old 03-28-2013, 09:47 AM   #7 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Mine is an on-off toggle on left side of dash, low down. It was in the car when I bought it, had been installed to control some lame fog lights which I've since removed. I've seen these switches in parts stores, and probably also at Radio Shack. It had an internal light once but the bulb died.
I like the toggle. Flip it off to kill. I don't have to keep my finger on it. Flip it back on again after engine is stopped. That way it will restart whenever I bump it or key start it. It has a long toggle handle so it's easy to swat with a finger or two whenever I want.
Coast long and prosper.
Old 03-28-2013, 10:32 AM   #8 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I just used an on/off lightswitch from Lowe's. If it wasn't so obvious in it's current position I figure it makes a marveleous anti-theft device :-)
BTW, you can but momentary push button swithces on eBay 2 for a dollar (including shipping):
http://www.ebay.com/itm/2-x-MOMENTAR...item3a6f2c3052
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 03-28-2013, 10:39 AM   #9 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
I started with a toggle switch, but then changed to a momentary pushbutton. With the pushbutton, you hold it down for a second or two, then release and the engine is ready to bump start. If something comes up and you have to prematurely release the pushbutton, your engine is either stopped and ready to bump start or it is still idling.
The problem with a toggle switch is you flip it off, then if something comes up (traffic or passenger) that diverts your attention, it may cause you to forget to flip the toggle back on, then when you bump start, you get the dead engine sag until you remember that you forgot to flip the toggle back on and can flip it back on to get your engine power back. If you needed that engine power instantly to get out of a developing traffic situation, those seconds with a dead spinning engine could cause you some anxious moments.
aerocivic.com
Old 03-28-2013, 12:05 PM   #10 (permalink)
mozul's Avatar
Spitfire - '68 Triumph Spitfire Mk II
90 day: 26.18 mpg (US)
CivicHybrid - '04 Honda Civic Hybrid
90 day: 37.1 mpg (US)
Mine is a SPDT Miniature momentary switch I got at the local Fry's electronics. (on) off (on) is on the packaging to indicate it is momentary. I push it down to kill the motor and up to restart it. If I choose not to bump it. I don't like to restart with the key switch as that cuts out my stereo.
eoc, kill switch, metro
