Old 09-12-2015, 09:54 AM   #21 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Great thread! I'll be following along. I always liked that model of the Civic coupes. Should be a nasty little eco-machine. Don't worry about the wife. Mine feels the same way. That's why I removed the passenger seat, and saved even more gas!
Good luck.
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 09-12-2015, 12:01 PM   #22 (permalink)
Originally Posted by Donahue View Post
I wonder, do the HCH have electric steering racks? 7th gen SI hatchbacks do. If the hybrids do too, it might be another route for me to consider down the road.
Why wouldn't the setup from the hatchback be supposed to work in your coupé?
Old 09-13-2015, 01:13 AM   #23 (permalink)
Donahue's Avatar
White Lightning - '04 Honda Civic HX
90 day: 40.5 mpg (US)
All though the 7th gen hatchbacks really don't share much in common with the rest of the 7th gen, the racks are compatible. They are also rare and expensive. Maybe using a hybrid one would be less common and therefore cheaper.
Old 09-13-2015, 01:37 AM   #24 (permalink)
Indeed. Though I'm not sure about the steering rack of the hybrid featuring EPS, there might be some other EPS setup you could retrofit into your Civic, as it's becoming increasingly popular.
Old 09-13-2015, 08:50 AM   #25 (permalink)
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
Sweet HX! I was looking for a seventh gen before I picked up Slambo ('99), but they are tough to find around these parts.
I saw a nice MPG bump with an EGR clean. Put that one on your to-do list. =)
Working on the rear belly pan now. Just had my best legit tank.
https://youtu.be/zFl6n1T1FCw
I'm not keen on losing the mirrors or installing a kill switch, but it's a hoot to throw into neutral and glide.
Ain't Fuelin' - The Beater Build Show :
https://www.youtube.com/playlist?lis...R754kIg_V8Aahm
Old 09-14-2015, 10:23 AM   #26 (permalink)
Donahue's Avatar
agreed on the mirrors, I'll accept the aero penalty. I'm coasting now using the key, i can coast the last mile to my house and even with a couple of turns onto different streets, ive got enough momentum to pull into my driveway. the brakes seem to be fine when off, either there is plenty of vacuum reserve, or the vacuum assist isn't super powerful to begin with. But EPS would be nice, or maybe just removing the PS and convert to manual.
Old 09-14-2015, 10:39 AM   #27 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I have a 7th Gen also (2003) and I've been running the stock power steering rack with the reservoir and pump completely removed. I don't really notice any situation where I have problems arise as a result. You may want to try this first and save yourself the cost of buying an all new rack!
The Following User Says Thank You to whatmaycome14 For This Useful Post:
darcane (09-14-2015)
Old 09-14-2015, 12:36 PM   #28 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I did this too; it worked fine for 2 1/2 years (until the car was totaled). I used this tutorial.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 09-14-2015, 03:24 PM   #29 (permalink)
darcane's Avatar
I get about three full pushes on the brake pedal before the pedal gets hard. Even then, it will still brake OK, but I typically start the engine and kill it to build up vacuum again. If you have lots of downhills where you regularly run out of vacuum, you can add a vacuum reservoir.
My power steering is disabled. I don't miss it a bit. It's a light car, I don't feel it is needed at all.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-14-2015, 03:59 PM   #30 (permalink)
Would you actually consider to delete the brake booster?
