Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 06-18-2011, 01:17 AM   #21 (permalink)
How does a hub motor slip?
Old 06-18-2011, 01:47 AM   #22 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
Those 5 planetary gears used to engage inner (motor) and outer (rim) surfaces like a centrifigal clutch. It used to go zzzzchchchc (solid) but now it goes zzhhzzhhzzhhzzzhhhhch (not as smooth now). If my description makes any sense to you - congratulations I just have to be easy on the acceleration and everything is fine!
Old 06-18-2011, 03:54 AM   #23 (permalink)
I did understand that (more or less).
I'm pretty sure mine has no gears at all; I didn't know there were geared motors.
Old 06-18-2011, 10:47 AM   #24 (permalink)
Name might throw you off - usually described as "can" motors; with a gear bolted onto the normally non-geared end of the hub. Then a small chain goes to the motor, or "can". Mine was a 2001 Currie and it lasted past 2007 when I got the much quieter hub motor.
It was great fun when I lost traction and spun the back wheel. Not so much fun when I snapped that small chain though!
ID:	8742   Click image for larger version
Old 06-19-2011, 08:08 AM   #25 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
For commuting to work, a pedal bike is best up to about 3 miles. You don't have to pedal hard and sweat, and you are just warming up at that distance. The electric bikes range varies but a typical lead acid 48V-12aH system will get you maybe 15 miles (more if you don't use the throttle as much). So the electric bike is best for trips of 3 to 7 miles if you don't have a place to plug it in, and 3 to 15 miles if you do have a place to plug it in.
I went through 3 sets of 4 batteries each over about 5 years. I think a set cost about $120. I finally got tired of paying for lead acid batteries that do not last long. I used the bike quite a bit but it seems like batteries should last more than a year.
I would like to try lithium batteries but never seem to be able to cough up enough cash to get a pack. It would probably be $400 to $600 to get a battery system (I haven't checked lately).
The real reason I stopped riding the electric bike is that I need exercise and riding (or walking) to work is great exercise.
Nissan Versa Aeromods
Old 06-19-2011, 08:25 PM   #26 (permalink)
I think my SLA pack is 3 years old now and it's about as good as ever...
Old 08-05-2011, 03:12 AM   #27 (permalink)
BarelyAWake's Avatar
I initially purchased SLAs for my project, as it's a hybrid range wasn't as critical... but I ended up replacing them with LifPo4 packs from Li Ping ("duct tape" packs) simply due to weight concerns...
...and yea, they are a bit costly - but a 48v 15ah LifPo4 pack is about 16lbs whereas 48v 12ah SLA is close to 30lbs *shrug*
Electric Motorcycle conversion bennelson Fossil Fuel Free 315 01-27-2018 03:51 PM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
Dirt-E Bike (Kawasaki KE-175 Electric Conversion) FrankG Fossil Fuel Free 10 10-08-2008 05:38 PM
Electric bike hub Lazarus Alternative Transportation 19 01-04-2008 08:34 PM
Electric bicycles: now legal where I live (Ontario) MetroMPG Alternative Transportation 1 11-28-2007 08:36 PM
