Old 07-28-2009, 05:03 PM   #1 (permalink)
Matt Foley's worst nightmare - '09 Chevrolet Express 2500
Why get a vacuum gauge...
Why get a vacuum gauge if I already have an mpguino? Is it beneficial or is my money better spent elsewhere?
Old 07-28-2009, 06:42 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Well they can be had for ~$10, I never figured out how to use it effectively but I really really liked the responsiveness of an analog gauge.
Old 07-28-2009, 09:49 PM   #3 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
I use my vacuum gauge as my primary instrument and then confirm its benefit with the MPGuino. Keep the vacuum as far away from 0 as you can (within reason, you'll see) and then see what the MPGuino is telling you. You do have to compromise on hills and during accelerations but you get used to the instantaneous info. It is a great way to gauge where your throttle position needs to be once you are used to it and the drive you do most often. Another trick is when you are driving at constant speed and power like on a long stretch of road. Lift you foot just ever so slightly and see the response on the vacuum gauge. You end up at the same speed but more vacuum and less fuel used.
I love mine!
Old 07-28-2009, 10:53 PM   #4 (permalink)
...beats walking...
VACUUM gauge = old-style, proven, analog, fuel-economy display device.
MPG Gauges = new-style, proving, digital, fuel-economy display device(s).
...best of "both" worlds!
Old 07-29-2009, 10:44 AM   #5 (permalink)
Stormin' Norman
Stormin' Norman's Avatar
I haven't been around for quite a while, because I did the impossible (almost) and empowered my humble Fairmont wagon with a full set of 1984 Mustang gauges, including the Trip meter, and then added a voltmeter and vacuum gauge. Now I can see what the engine is doing and catch fuel usage changes by the tankful.
Here's some of the things that a vacuum gauge will tell you:
Vacuum Gauge troubleshooting
If you're a Ford fan - click on the combo box for some tech info:
efv8 - Tech Tips
What I like about that graphic (right-click and save picture as...) is that it prints out into a small enough page for the owners manual. Handy on the road.
This one shows one dynamically through 15 different conditions:
How to Use and Interpret a Vacuum Gauge
Another downloadable chart for GMers:
Reading your vacuum gauge
A decent bit of tech detail about the Vacuum gauge:
Using a vacuum gauge
My car doesn't have all the bells and whistles for a Scanguage or other Hi-tech monitoring. In fact, because it was built in Mexico, it didn't even have Electronic ignition. After upgrading to a freshly dealer-rebuilt 3.3L I6 and transmission, it finally matured into the E-age.
After seeing all that a Vacuum gauge tells me, I wouldn't own a car without one! It's the early OBDII, as far as I'm concerned.
That goes for the voltmeter too. Up here, in the cold Canadian Prairies, your life depends on the charging system. The Ammeter just tells me how much the car is using. The Voltmeter tells me the system is charging, good, bad or not enough.
1979 Fairmont Squire (Built in Mexico), 200CI, C4 Auto.
Nothing replaces common-sense. It just seems to be a commonly scarce commodity.
The Following 3 Users Say Thank You to Stormin' Norman For This Useful Post:
ECONORAM (05-15-2010), Phantom (06-01-2010), TEiN (09-01-2009)
Old 07-29-2009, 02:29 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Stormin' Norman -
Thanks for the post. I think of the vacuum gauge as a "heart monitor" for the engine, not just an old-school MPG device.
CarloSW2
American Solar Energy Society
Old 05-15-2010, 09:17 PM   #7 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
I like using a vacuum gauge with the MPGuino. It is interesting to see the changes in fuel flow despite the fact I do not change throttle position, but the vehicle shifts (or something else happens). Watching the vacuum gauge also helps me determine when I am getting a slight wind break from vehicles ahead of me (if the cruise control is engaged).
Old 05-15-2010, 10:02 PM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
If you're like me and also trying to get the most possible miles per car, then you may be driving something with not a lot of electronics for the mpguino to hook up to. Vacuum gauge, Mk I eyeball, Foot 1 and Foot 2 are all the instrumentation I've got.
Old 05-16-2010, 07:07 PM   #9 (permalink)
...beats walking...
...think of a VACUUM gauge as a mechanical intake-SPIROMETER for your car.
...SPIROMETER is an apparatus for measuring the volume of air inspired and expired by the lungs.
Old 05-17-2010, 12:36 PM   #10 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I'd use it to look for thumps at speed (shaking needle)...
and unusual low at idle. That is about it. I do not keep one hooked up.
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Vacuum gauge: all or nothing! elhigh Instrumentation 2 04-23-2009 08:57 PM
Tach & Vacuum Gauge Installed midnight rumbler Success Stories 8 01-01-2009 01:33 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
