Old 08-17-2010, 01:36 PM   #21 (permalink)
The PRC.
Interesting, I didn't look at the speed the SG2 puts out, its not a gauge I used - I assumed it was getting the same signal from the ECU that the instrument pack gets so I never checked that with GPS.
And I did a trip last week involving GPS - DOH!
Looking forward to more info and notes to compare against
Whats your static and max MAP ?
Old 08-17-2010, 05:43 PM   #22 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
so if the ratings in europe dont reflect reality-is there a certain generic weighting you can apply to the figures to give indicative values?
Old 08-18-2010, 04:53 AM   #23 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
My instrument panel claims 103-105 km/h when the GPS says 100, the ScanGauge agrees with the GPS.
I believe it's something about speedos showing a higher speed than actual for both safety and performance reasons. But the real info is in there, only the speedometer signal is scaled.
Old 08-18-2010, 08:41 AM   #24 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That's exactly what I have found as well.
The Scangauge reads the same as the GPS.
Speed indicated on both is within 1 km/h - which is the smallest variation both show.
The Volvo tacho OTOH, reads some 3 km/h high all across the normal speed range.
BTW : The Volvo CC is very good at keeping a very steady pace.
Old 08-18-2010, 08:46 AM   #25 (permalink)
euromodder's Avatar
Using 20-25 % more fuel than the official fuel rating is still considered to be normal ... or even good FE.
Nobody really expects to be able to achieve the official FE in their daily driving.
Old 08-18-2010, 08:51 AM   #26 (permalink)
euromodder's Avatar
I'll take a look.
I didn't have MAP showing.
Turns out I'm not getting FPR IGN TPS TFC and LP inputs
FPR is seldom reported according to the manual, but I'd have liked to see the other values.
Old 08-18-2010, 02:56 PM   #27 (permalink)
aero guerrilla
Piwoslaw's Avatar
I glanced at mine a few times. Idle pressure is under 15, the largest I've seen is 31, but it could be more as I usually keep my eyes on the road when accelerating hard.
Don't expect IGN in a diesel!! I also don't get LP, TFC or FPR either. I'll have to see if I have TPS.
Old 08-19-2010, 12:04 PM   #28 (permalink)
euromodder's Avatar
Idle @ 14.5 kPa
Max. I've seen was just over 33 kPa (going up an incline).
Min. 11.5 kPa (engine braking)
Doh ! What was I thinking ...
Though the tank is not looking really good anymore (remaining distance is dropping like a brick), I'll go over 1000 km/tank - but probably not by much.
Old 08-20-2010, 03:43 AM   #29 (permalink)
euromodder's Avatar
1045 km @ 4.58 L/100km (51.4 mpg)
It has taken some effort, but I finally got my first 1000+ km tank
1045 km (649 miles) with 60 km remaining range indicated
Fuel economy was also a personal record : only 4.58 L/100km or 51.4mpg (US)
Guess what : I forgot to use the fill-up function of the ScanGauge. Doh !
Old 08-20-2010, 08:23 AM   #30 (permalink)
Team m8
Congratulations! thats some good mileage!
Cordless Electric Lawn Mowers Do Work! rgathright Saving@Home 21 12-09-2011 10:08 AM
From 15 to 23.75mpg in a 5500lb work truck JacobAziza EcoModding Central 21 12-04-2009 01:38 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 11:45 AM
Scangauge doesn't work lovemysan Instrumentation 2 09-01-2008 10:49 PM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 10:03 PM
