Old 07-05-2012, 06:55 PM   #281 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by euromodder View Post
I had a 306 DT - same crap.
Next car can't be PSA , PSA-engined , PSA-built nor can it be blue
Companies that have ties with PSA (like Toyota, BMW through MINI) will be frowned upon ...
Skoda Felicia 1.9sdi estate.
You've ruled out ford/Mazda etc with the 'no PSA' rule..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 07-05-2012, 07:15 PM   #282 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Their diesels anyway.
The petrol engines aren't PSA made or developed, while the ecoboost range is a Ford development AFAIK
No more diesels for me.
Old 07-13-2012, 11:41 AM   #283 (permalink)
euromodder's Avatar
I've ordered some dimple tape just for fun.
The turbulator tape is in.
In photographs it appeared to have thermo-formed dimples in clear tape.
In reality, they're fairly rough holes punched through the tape.
I'll need dry weather to install it though.
The hot air issue seems to be sorted.
Repeatedly turning the temperature knob from minimum to maximum seems to have done the trick.
I've done a short tank without any DPF regenerations, just to see what the effect would be, and was rewarded with a record 4.09 L/100km or 57,75 mpg !
Half of that tank was driven in the pouring rain though.
The dry half showed 0.2L/100km less on the OBC, so I would have beaten 4L/100km (59 mpg) if it had been dry !
D@mn.
Old 08-22-2012, 04:24 PM   #284 (permalink)
euromodder's Avatar
And now it's on
I don't expect any great gains from it, but we'll see what gives.
Tape and dimples / punched holes are only 1.5mm thick - probably way too thin.
The rear bumper toes in a fair bit, but the lower part is rounded rather than ending in a sharp ridge to allow for air separation - as Volvo did on the taillights.
The idea here is to draw more air into the wake by keeping the air on the bumper a bit longer.
Rear hatch, again, rounded off from roof to rear window.
The idea again is to bend the air into following the body lines.
The upper taillights are rounded, getting ever more squarish as it goes down.
The side window rubber is probably already stirring up the air there.
Mirror. Two strips of turbulator tape on top, one below.
Windshield / A-pillars. One strip across the top of the windshield, clearing the wipers, and a strip on either side on the A-pillar.
Looking forward to changes in air flow while driving in the rain - the rain would always spill over onto the side window.
ID:	14070   Click image for larger version
ID:	14071   Click image for larger version
ID:	14072   Click image for larger version
Old 08-23-2012, 06:42 AM   #285 (permalink)
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 39.08 mpg (US)
Are you planning any serious testing? The strips look kind of pale next to the shark-fin roof-top VG, don't they?
Also, I'm confused as to what is more beneficial - trying to bend the flow to "fill the wake" (rear bumper) or having it separate cleanly (rear lights).
Oh, and hi everyone! (first post)
Old 08-23-2012, 03:35 PM   #286 (permalink)
euromodder's Avatar
No.
If there's any benefit, it'll be small .
It'll definitely get lost in the daily variations.
The + :
The car is definitely quieter !
This series (C30/S40/V50) has been troubled by questionable A-pillar aerodynamics, and as a result lots of wind noise.
It seems to be replaced by a slight whizzing sound .
The - :
The strip on the underside of the passenger mirror is already gone.
The strip on the windshield has come loose over 4-5 inches.
Maybe I should have prepped the surface better
Yeah
The dimples are really tiny .
I share your confusion
Round or round-ish rear ends are to be avoided at all cost - they increase drag, see Coanda, and on a trailer can lead to handling issues in sidewinds.
But the curves are already there, so I'll try to make it work to my advantage.
Old 08-23-2012, 04:37 PM   #287 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Check out where I get dust deposits on the rounded rear lights of my Peugeot. The pictures show where the airflow starts to detach, gradually slowing down enough for the dust to stick. If the rear had a sharp edge, then there wouldn't be any deposits.
Ah, i witaj na EcoModderze
Old 08-26-2012, 08:34 AM   #288 (permalink)
Diabla - '09 Renault Laguna Hatchback
Hey euromodder, can I ask you where you got the tape from?
One time I bought something similar and it didn`t work at all for wind noise and that`s just what I would like to reduce on the highway.
Noise pollution is still pollution and it`s much more enjoyable to drive a quiet car.
Old 08-26-2012, 11:22 AM   #289 (permalink)
euromodder's Avatar
An online store for glider aircraft products.
They seem to help a bit - though that's subjective.
The tape is already peeling.
OK, I didn't somehow prep the surface of the car - no instructions came with the turbulator tape - but still ... that's quick to come undone.
Do they work ?
Definitely - though it won't show up in the fuel consumption.
During rains squalls, I used to have a big patch of water on the upper half of the side windows, running aft for about 1/3rd the length of the window. So something must have kept the water there.
With the turbulator tape running along the A-pillar , I now have a number of thin parallel streaks of water, almost top to bottom, angling down towards the rear, and extending over half the length of the side window .
So however small, these dimples are doing something, and that in itself is already amazing to me.
Old 08-26-2012, 03:06 PM   #290 (permalink)
aero guerrilla
Piwoslaw's Avatar
Almost like tuft testing...
Cordless Electric Lawn Mowers Do Work! rgathright Saving@Home 21 12-09-2011 10:08 AM
From 15 to 23.75mpg in a 5500lb work truck JacobAziza EcoModding Central 21 12-04-2009 01:38 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 11:45 AM
Scangauge doesn't work lovemysan Instrumentation 2 09-01-2008 10:49 PM
Request for 'work in progres' thread Daox Forum News & Feedback 4 12-23-2007 10:03 PM
