06-30-2016, 11:42 AM
#11 (permalink)
Originally Posted by mikesheiman
So I'm guessing 10-12 degrees is the suggested angle range for any and all tapers in the back (essentially along straight lines inward)?
The 10-12 degrees applies to flat surfaces (fastbacks), and yes they are easier to build than the curve of the forum's aero-template.
If you can pull off a 3D curved surface, go for it. Many people have done it, more than one way to get there too.
EDIT:...................................
I think the upward slope of the body and floor is half of the top's decline angle.
I did not draw a five degree slope up for the bottom of the tail, should be there though for driveway clearance if nothing else.
06-30-2016, 11:52 AM
#12 (permalink)
PSmodder lurker
Would appreciate elevation pics; front, sides, rear and top. Maybe a bottom pic to see your belly pan flow. Intakes, cooling and exhaust considerations too.
The Following User Says Thank You to botsapper For This Useful Post:
06-30-2016, 12:26 PM
#13 (permalink)
Originally Posted by kach22i
Aerodynamics by George Kachadoorian | Photobucket
A picture is worth a thousand words?
I included Frank's in-fill comment for the front wheel, that of course would be a rounded edge, just showing the concept here.
As originally presented, looks like one of those designs which would perform better backwards - sorry.
George, I think you nailed it.
Mike, question about the "shoulder" at the back of the sides - the area where George's sketched fill meets the suggested taper: is there something under there?
If the fill could continue down and in (rather than the "shoulder"), then it would be even better.
06-30-2016, 02:04 PM
#14 (permalink)
Ya know, I think we can be much more aggressive with our retreating angles of attack.
I recall discussing the latest Porsche 911 a few years ago, compared to my own vintage air-cooled model.. The old cars were about 27 degrees on the rear window, the liquid cooled ones of late are 20-22 degrees.
These are some of the lowest Cd cars on the market, many wind-tunnel images show attachment.
Be bold.
The 10-12 degree angle are for flat roofs like 1971 Ford Mustang Mach-1.
You have curves, curves love air and vice versa.
EDIT: I'm old and my memory sucks, looks like 16-17 degrees, but you get the idea, right?
I at least got my own car right.
http://s184.photobucket.com/user/kac...?sort=3&page=1
When you have time, check out this thread - long but good.
http://ecomodder.com/forum/showthrea...n-18632-4.html
And another good thread:
http://ecomodder.com/forum/showthrea...y-25809-2.html
It's less than 22 degrees, gradual incline and generously rounded corners.
Looks good to me.
06-30-2016, 04:15 PM
#15 (permalink)
PSmodder lurker
Just having fun...
The Following 4 Users Say Thank You to botsapper For This Useful Post:
07-01-2016, 11:50 AM
#17 (permalink)
This is a trike, so the side taper can be more aggressive.
07-01-2016, 12:19 PM
#18 (permalink)
PSmodder lurker
...totally different final shape then. Might need a 'naked' pic to see his hidden mechanicals, the pic looked like it had covered rear wheels
07-01-2016, 01:33 PM
#19 (permalink)
Yes, a 5:1 airfoil is 5x as long as its widest dimension. A 75% Kamm truncates the tail at 0.75 x the full length. A vehicle that is a maximum of 50" wide would be 250" long then shorted to 250" x 0.75 or 187.5" (15' 7.5"). You have some good sketches to consider. Something like a Mercedes C-111 or Lola T-210 front and a tail from the Riley XR3.
07-01-2016, 02:34 PM
#20 (permalink)
I'm not so sure about that.
Read this a couple of times.
And, agreed, it does look like it would perform better backward, but then how would/could I make it stable as a 3 wheeled vehicle and have enough headroom for the rear passengers? Not asking that as a rhetorical question...I may well (if only quite eventually) remake the car in such a body style eventually if it's possible.
The front does look more narrow than the rear, but I don't think it's a trike.
Hopefully mikesheiman; will chime in and provide the requested information.
