Old 07-14-2017, 09:33 PM   #1 (permalink)
Would running lean save fuel?
I know that an air fuel ratio of 14.7:1 is in stoichiomitry, obviously running rich burns more fuel, and running lean reduces performance. But what if a car ran at 15.5 or 16:1 air to fuel ratio at all times, except when cold, under heavy load or at full throttle? I would think it would get better mileage, at the cost of worse throttle response and higher temps. Why is the air to fuel ratio so rich while cruising? Could the engine not do the same amount of work with a leaner air to fuel ratio, or would fuel consumption increase? Thanks, this always confused me.
Old 07-14-2017, 10:06 PM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Law and emissions
The Following User Says Thank You to rmay635703 For This Useful Post:
EcoCivic (07-15-2017)
Old 07-14-2017, 10:48 PM   #3 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
This is where your EGR helps...lets you run less air and fuel without having to change your AFR.
The Following User Says Thank You to Stubby79 For This Useful Post:
Old 07-15-2017, 04:06 AM   #4 (permalink)
I tuned the carburetor on my gasoline powered suburban with the aid of my AEM wide band O2 meter for lean burn and it made about a 20% improvement over a properly tuned carb.
It works.
You do not want lean burn at high load, I burned all the exhaust valves on a fuel injected engine because I didn't know how to make it run rich at high load.
The Following 3 Users Say Thank You to oil pan 4 For This Useful Post:
EcoCivic (07-15-2017), Frank Lee (07-15-2017), rmay635703 (07-15-2017)
Old 07-15-2017, 09:20 AM   #5 (permalink)
rmay635703's Avatar
It works
Makes you wonder if having your car make a little more NOx but reducing fuel use 20% might reduce overall emissions since your taking a chunk out of the 300 grams of NOx per gallon the refinery makes?
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
EcoCivic (07-15-2017), Fat Charlie (07-26-2017)
Old 07-15-2017, 09:53 AM   #6 (permalink)
CruzeMTgrind
BlueBawls - '14 Chevrolet Cruze Eco
90 day: 48.47 mpg (US)
Eddie - '02 Ford Explorer Eddie Bauer
90 day: 23.07 mpg (US)
That matches my thought process. Not sure how much NOx a car in lean burn mode would produce. But 20% less fuel use should make up for that in my eyes especially if what your saying about NOx the refinery makes is accurate.
The Following User Says Thank You to ecocruze For This Useful Post:
Old 07-15-2017, 09:55 AM   #7 (permalink)
Where I live we do not have a NOx problem.
It's flat as far as you can see and one of the windest places in the united states.
Unfortunately EPA only cares about vehicle tail pipe.
I had no idea the refinery made 300gm of NOx per gallon.
Heck it's almost like the government is intentionally making the problem worse.
I have been around oil refineries and they do smell like NOx, but I didn't even think it was possible to release that much.
Old 07-15-2017, 11:11 AM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
That sounds extremely high. Do You have a source for this?
Old 07-15-2017, 11:47 AM   #9 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
If you do this on a 25-year-old car in USA then I'm pretty sure you're in the clear when it comes to emissions regulations.
Old 07-15-2017, 12:37 PM   #10 (permalink)
Dark Egg - '12 VW Touraeg
Anyone who thinks the government produces regulations to help the average person is crazy. Maybe 100 years ago. The regulations are written by lobbies and special interest groups to carve out an advantage for themselves. Who benefits from using more gas and adding expensive parts to cars? In the name of reducing NOx which supposedly helps the common man. Must be nice every time the common man gets "helped" a CEO makes another billion.
The Following 2 Users Say Thank You to Hersbird For This Useful Post:
ecocruze (07-15-2017), Fingie (07-16-2017)
