Old 12-28-2011, 11:46 AM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
You guys are doing it wrong
Instead of worrying about fuel economy and aerodynamic desinsg you guys should leave well enough alone. Instead work on a "tractor beam" like in star wars so you can beam onto the car ahead of you and let them pull you along. Kind of like drafting. Let him worry about his mpg while you just coast along behind with the engine off
If that idea is to futuristic at least have some telescopic electromagnets that you can attach to the car ahead of you and use high test fishing line to connect
Old 12-28-2011, 12:29 PM   #2 (permalink)
90 day: 29.78 mpg (US)
I have entertained the idea of an electromagnet attaching to a big rig for freeway travel. The driver would probably not even notice the extra load on flat ground. It's those pesky laws that I'm really worried about though.
Old 12-28-2011, 12:46 PM   #3 (permalink)
True. Plus the fact that for a lot of us, it's not really our personal fuel consumption that's the fundamental issue, it's the effects of burning petroleum. Thus if I reduce my consumption X amount by causing someone else to increase their consumption by the same amount, I've achieved nothing.
PS: Though drafting a semi should also produce a small aerodynamic benefit for the semi...
The Following 3 Users Say Thank You to jamesqf For This Useful Post:
Cd (12-28-2011), NeilBlanchard (12-31-2011), Piwoslaw (12-29-2011)
Old 12-28-2011, 04:56 PM   #4 (permalink)
For highway travel, it doesn't make sense that thousands of vehicles moving in the same direction and roughly the same speed should individually power themselves. It would be like having an engine attached to each boxcar of a train. Gasoline engines are incredibly inefficient when operating at such low sustained loads.
Attaching your vehicle to a truck and turning the motor off would save a lot of fuel, even when considering the loss of MPGs experienced by the truck.
Old 12-28-2011, 05:09 PM   #5 (permalink)
...beats walking...
...big problem with a "train" is that if/when somebody in the middle needs to turn-off for gasoline or potty break, everybody behind him are suddenly gonna be "coasting" much to their surprise!
Old 12-28-2011, 05:23 PM   #6 (permalink)
Vactrain - Wikipedia, the free encyclopedia
Evacuated tube transportation technology.
A ride in a 0 atmosphere tube after being fired by a magnetic rail gun, slowly enough to keep you from disintegrating on your way to 5000 MPH.
regards
Mech
Old 12-28-2011, 05:47 PM   #7 (permalink)
regards
Mech
I've always thought it would be quite efficient to send satellites to space using an evacuated tube and rail gun. I just don't know what kind of heat shield would be needed for when the craft exits the tube, or if the sudden impact of hitting 1atm at ~20,000mi/hr would pulverize everything. Build this gun on top of a tall mountain near the equator and you can cut it down to 0.5atm and reduce the required velocity.
Old 12-28-2011, 05:48 PM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
Why bother with a tractor beam when you can just make a transporter?
Old 12-28-2011, 05:54 PM   #9 (permalink)
Oh, I don't know... maybe tear around less?
Old 12-29-2011, 09:24 PM   #10 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Why bother going anywhere at all? You're already someplace.
The Following User Says Thank You to Ladogaboy For This Useful Post:
wdb (12-30-2011)
