Go Back   EcoModder Forum > cfg83's Profile > Albums > Air Dam
Picture 2 of 5 from Album Air Dam
Spring mounted air dam.  Air dam is made of two parts, each slightly angled "cowcatcher" style to push the air to the sides.  Each side of the air dam is attached using a piano hinge to block the air.  The last 8-10 inches is not attached so that it can be bent by the oncoming air.  The center has a generous gap to keep each side from hitting with each other.
Picture Added 12-29-2011 08:44 PM
Added by cfg83
